after a lot of grunting, swearing, 50cm of oil line, 2 stanley knives, 2 more pieces of aluminium, and a some masterwork with a pair of tinsnips...
... i think im done.
Seriously Dave.... just watch a porno or hire a hooker like the rest of us. :(
Turns out i am going to have a custom made intake pipe and catch can made for my car while its off having stuff done...hopefully it doesn't delay it much longer. Morrie is trying to get it out on Friday...here's hoping.
shortest working day ever. well, 2nd shortest. spent an hour before work chatting up one of the girls who started a few months before me, and then went to spend all of 5 minutes on the clock. i love this job sometimes.
been there. tried that. but snorting a line of blow off a hookers back while spanking her with a toasted cheese sandwich just doesnt provide the same level of dirty satisfaction.
What do you do?
R32 peepz, Are R32 Headlights easy to remove? What is to be removed to get them out, and do the lenses come apart from the actual light as mine all of a sudden got a little moisture in the drivers side and I want to open it up and clean it out :(.
i told you weezy, i deal for a crust.
to split the headlights youll need to basically bake them to melt the sealant...
but actually removing them should be a cakewalk. just poke around the place with a screw driver, youll figure it out.
Edited by scandyflick
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
    • Did you hit up the search function? R33 and greddy and cable returns this thread with some options.   https://www.sau.com.au/forums/topic/358214-rb25-throttle-body/
    • Thanks buddy.. the standard one needs to be about another inch or inch and a half longer. Thanks anyway
