after a lot of grunting, swearing, 50cm of oil line, 2 stanley knives, 2 more pieces of aluminium, and a some masterwork with a pair of tinsnips...
... i think im done.
Seriously Dave.... just watch a porno or hire a hooker like the rest of us. :(
Turns out i am going to have a custom made intake pipe and catch can made for my car while its off having stuff done...hopefully it doesn't delay it much longer. Morrie is trying to get it out on Friday...here's hoping.
shortest working day ever. well, 2nd shortest. spent an hour before work chatting up one of the girls who started a few months before me, and then went to spend all of 5 minutes on the clock. i love this job sometimes.
been there. tried that. but snorting a line of blow off a hookers back while spanking her with a toasted cheese sandwich just doesnt provide the same level of dirty satisfaction.
What do you do?
R32 peepz, Are R32 Headlights easy to remove? What is to be removed to get them out, and do the lenses come apart from the actual light as mine all of a sudden got a little moisture in the drivers side and I want to open it up and clean it out :(.
i told you weezy, i deal for a crust.
to split the headlights youll need to basically bake them to melt the sealant...
but actually removing them should be a cakewalk. just poke around the place with a screw driver, youll figure it out.
Edited by scandyflick
    • UPDATE: Yes the GSP Axles are compatible. I installed it on my R34 today and they are working a treat! Turns out that the S13, S14, S15, and 200 SX all used the same axles as the HR34, and ER34 NA models. Which is 2 bolt x 3 pairs.
    • Also build this EH ute with 370z motor and gearbox with a couple of turbos just for fun.
    • Got the passenger door on plus the master cylinder and booster. Loaded up to take it home. At home, the colour changes a lot in the light.
    • Nothing cheap, but I have seen the AC Hydraulic DK13HLQ which is pretty close to what you're asking for. The problem is the hydraulic cylinder mandates that the back of the jack be a certain height and Skylines have fairly deep inset floor jack points. A more certain and cheap option is to get some nominal 2x10 inch lumber boards and have one board be 1.5 feet, the other board 3 feet. Glue it all together with lots of clamps to maintain pressure. Make two of these. The ramp suggested above is a good idea, it takes quite a bit of clutch slip to get over each of the boards. I only need the first ~1.5 inches for my low profile jack on a standard ride height car but a lowered car you want to go up to the full ~3-3.5 inches. Paint it or store indoors if you want it to last.
    • Ok. And Nistune? I read (here too) mainly on Stagea threads that it can by "turn off" with Nistune. But they say they still had the sensor plug in. Next week iam going to the Nistune(and other ECUs) tuner so i can finally make it work. I drove the car home and apart from the cut it drove great. No misfire no smoke no hesitation or rough start...so hoping it is this sensor that is missing
