Just got back from a little city and Eagle on the Hill cruise with Munro in the 35. Damn that car is fast (and hot). Stopped at the BP Hampstead Rd on the way home and you shoulda seen the crowd that gathered around it :(
Just got back from a little city and Eagle on the Hill cruise with Munro in the 35. Damn that car is fast (and hot). Stopped at the BP Hampstead Rd on the way home and you shoulda seen the crowd that gathered around it :)
i reckon i may have saw you. to the spotted thread :(
and scandy my bros should arrive in aus in the next couple of weeks again i wont be test driving, after a brief phone call she understands the words hello :) gonna be an interesting convo going on when she gets here.
Edited by Inline 6
Well, the results are in if anyone cares... Had a boost controller issue, only able to wind 16psi into it but still good numbers!
Pretty good number there :( What other mods did you end up doing? or are you just running the same setup as me?
I'd be interested to see what it makes on a mainline.
Soooo wouldnt mind this:
A mate of mine has one. With a few mods too. They're definitely not a shy car. :P
I wouldn't say no to one in my garage.
Another mate has recently bought himself a 370Z with a few mods. I'll be going for a spin in it shortly when it arrives :P
Guest
    • There's restrictor pills in the stock boost control hoses. That's how they set the amount that was bled off and hence the "high" boost setting. The usual mod in the day was to remove it and send the "high" boost setting up to about 14 psi.
    • Thanks Duncan, that's the best info I've read. Furthermore after learning about the PCM programming side controlling the factory boost solenoid, the purpose of the solenoid is to "bleed" boost when pin 25 is earthed, thus allowing spring pressure in the wastegate actuator to overcome diaphragm boost pressure, thus closing or reducing the position of the wastegate flap creating more boost as the turbo is able to spin faster. It's pretty cool to see a designated Pill to do exactly this, would have liked to have seen it with a tiny filter over the end for those moments in vacuum.  The constant bleed pill has now been removed completely from the system and solenoid boost control has been restored once again.   Case closed 😂
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
