The editor says about his drive the next day in a R34 GTR -
"And with the drive scheduled for the next day, did I have trouble sleeping the night before? Nope. In fact, it filled me with - literally - about as much excitement as I would have had when facing the prospect of driving any car that's new to me. Like a Hyundai Getz, for example."
Now read what he says after his drive...
"But in the way it went around corners - not just in speed but in feedback and communication and predictability - was something I have never before experienced.
Absolutely blindingly good. A true redefiner of benchmarks.
And I sure have never said that before of anything with a 'GT-R' badge.
Finally, here is a car that lives up to the hype."
https://www.sau.com.au/forums/topic/18843-see-the-gtr-article-at-autospeedcom/
I think he is actually the founder of Autospeed, and i recall he use to do articles for Fast Fours (back in the early 90s, maybe was even editor) then started up Zoom magazine.
Everyone is entitled to an opinion, he actually owned an R32 GTR so is only conveying his experiences with his car.
He made it pretty clear he prefers AWD cars such as his Liberty/Audi etc over the Nissan/Porsche 4WD Systems.
I have never been in an R32 GTR driven in anger so cant speak for myslef, but its interesting to hear someone elses opinion, even if it goes against the general consensus.
Guest wilco
He owed an Aussie Nissan imported R32 GTR, GTR-111 from memory, he is an okay guy just seems to have a lot of people that don't like him.
There seem to be a few speed shops around Adelaide that don't think much of him either, I don't know what he did to deserve the bad rap tho.
Didn't he move to Brisbane or some shit though?
I doubt its the reason ,
...but his magazines/publications do expose certain practices/modifications to be myths, and does encourage the DIY philosophy. Either shops dont get as much business as a result or they have to fix the backyard mess thats been created after reading such an article.:)
I like JE, He tells it how it is! or at least how he thinks it is.
I think the GTR just didn't serve his purpose!
.....and lest face it does a 32 really handle? or is it just fun to drive with power oversteer?
Simmo
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
