aaron has again disappointed me.
ive just received an email saying that he didnt want me to take it to GCG for them to strip the turbo, and this has voided my warranty.
i have no option than to sue, right?
Wait on, who told you to go to GCG in the first place?
  • Replies 72
after hearing that a friend of mine had his sliding turbo fail, the oil problem really started to worry me, so i pulled it off and sent it to GCG under aaron's instructions, as he told my friend to do also.
Edited by abu
aaron did.
he specifically told me to go to GCG, this is the exact line he used from our msn conversation.
bits were removed as to not let too much of aaron's situation out.
10/09/2007 12:36:27 AM Aaron Joe Rulz... are you able to take it off and take it to gcg to see what they think?
10/09/2007 12:37:58 AM Aaron Joe Rulz... well when you can take it off and send it to gcg and let jase know
10/09/2007 12:38:35 AM Joe Rulz... Aaron so i take it to gcg, then what?
10/09/2007 12:39:06 AM Aaron Joe Rulz... see what the prob is and let jase know
10/09/2007 12:39:18 AM Aaron Joe Rulz... if something has failed he will organise replacement
10/09/2007 12:39:32 AM Joe Rulz... Aaron how dude?
10/09/2007 12:39:44 AM Aaron Joe Rulz... organise through gcg
Common man, fair go... Slide was offering a cheap service and he's offering to repair the turbo for you. I wouldn't sue but that's me, how do you know it wasn't how you installed it or oil line mods that made the turbo fail?!?!
I've got a slide hiflow, no complaints. I'm sure proportionally the amount that have failed to the amount that have not would favour heavily towards not failing.
MO
Hi Guys
Our warranty procedure is pretty clear in that the item must be returned back to base for any work to be done.
The item is still under warranty Joe and warranty on the turbocharger is still available though in most circumstances if the turbo has been pulled down alot of things can be changed that in the repair would not usually be viewable and this would generally void warranty.
The turbocharger had been sent back to the shop before where it was pulled down and there was no problems at all other then reported.
We advised that you take the turbo to a local shop as you did not want to send it all the way up to the shop in QLD for us to view it for it to only be reported that it was not faulty as it was last time as you needed your car on the road.
If GCG have advised that a repair is required then under warranty Murnane Motors must be the shop to do the repair to it.
All warranty return procedures are listed on the website and have been there since its inception.
You have been advised via email on the warranty procedure.
If you would like a refund on the item then that is available for the purchase price less postage and housings as advised also via email to retrieve from Murnane Motors which i doubt would be a problem though if you just ask the manufacturer im sure they would give you a straight answer.
It does seem as if you just don't want to send the turbo back.
The warranty procedures are common practice amongst all manufacturers in that they must be returned to the manufacturer for repair.
Thanks, Aaron
MO
if it was a way that i installed it then there would be scores on the shaft from oil starvation, or oil contamination. GCG have stated that there is no scoring or oil contamination.
i've installed plenty of these turbos and have not gone wrong.
he just told me by email that my warranty is VOID because GCG had opened up the turbo.
wheres the fair go?
Hi Guys
If you would like a refund on the item then that is available for the purchase price less postage and housings as advised also via email.
Thanks, Aaron
you told me to take it to GCG because you have no workshop. i have you telling me this in an msn conversation which i kept the logs of (and which i removed from the conversation i pasted above).
i have no problems with them doing the repair as i said earlier, but you told me that i pretty much voided my warranty by having GCG inspect the turbo WHICH YOU ADVISED ME TO DO.
Aren't these turbos sold as 'Sliding Performance'? shouldn't they be warranted by 'Sliding Performance'?
No wonder Joe doesn't want to send it to Murnane when 1 - he's never heard of them before, up until today 2 - his contract is with SP and 3 - they've 'repaired' it once already!
thats exactly how i feel.
ive never heard of these guys before today. my last repair i sent my turbo to aaron himself.
thats why im a bit reluctant on sending it.
if HKS came up one day and said, 'ok, we actually dont build our branded turbos, k-mart does'. how would you feel?
so send to slide and they will forward it on
sounds like your angry about the sit and not thinking straight get the thing fixed for free and resell it
I dont see how you'll loose any cash apart from postage the $75 and second install time
which probably adds up to under $300 is it really worth the agro
Im sure if you stop trying to play hardball slide will to
funny you only got the email about voiding warranty after you mention consumer affairs and sueing
Edited by 1400r
Just a bit out of the blue here but Slide are the Seller just like if my Panasonic copier craps itself, panasonic dont fix it the repair agent does (not panasonic), just like if a Sony tape drive fails i send it back to a company in brisbane (not sony) for them to repair it.
This procedure of sending the Turbo back to Murnan is normal, thats who built it thats who needs to fix it, if slide sell the turbo as a "slide turbo" thats fine, warranty Can if they choose go to slide then they send it onto Murnane, its quicker for you to send it to these guys directly.
As for the whole sueing bit, the only obligation slide would have to you is to send your turbo back to Murnane thats it, for warranty repair, if you have not as of yet sent it to them there is no case, I can see you would be annoyed if Aaron told you to take it to gcg withour telling you that you would ware the cost or it may void warranty, that is a big mistake if this is true.
Send it back get it repaired under warranty, make sure they know who you are in case you have future issues, share your concerns with murnane so you know they will take extra care on the job and if it craps itself again then you have a case to get a refund (maybe not full) or call fair trading, but you must give the normal warranty procedures a go first.
And most good jap parts are now made in china buy a guy paid $1.43 a week working out of his barn with his wife lol (quality aint what it used to be)
Edited by Mark0
Don't you have a one off, one of a kind 34 type hi-flow with a larger exhaust housing? Or was that someone else...
Either way, I reckon take the list from GCG, get a free fix under warranty, have GCG check it out at the end...
But sup to you really...
HKS dont build thier turbos, Garrett does and HKS markets them..same deal here Slide markets them and the other mob makes them but yeah sonds like a screw around I would be wanting my cash back too and be done with it
yeah but you got what i mean, right? its just a shit go.
i want a refund. but the turbo is in pieces at GCG and i dont think aaron is willing to have it returned like that.
yeah man thats not real good hey
yea lol like the time i complained my hiflow wouldnt line up and i had to line up the housings.
And i was at fault for "bending the oil lines". load of crap. now im "banned from dealing with sliding performance" lmao. like i care..
want real service talk to Amec :wub:
cheap and reliable turbos too :cool:
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
    • Oh, you are right. But, in Australia E10 is based on 91RON fuel and ends up being 94RON. Hence it being the cheaper option for economy cars. The more performance oriented cars go for the 98RON fuel that has no ethanol mixed in. The only step up we have left then at some petrol stations is E85.
