Where are you located ? I'll coat the ones that you think are giving you probs for free with polyester resin ! What have you lost ? If it works good ! If it dont them buy the ones you need ! Thats a hell of a saving if it works.
where do you get this polyester resin?
you reckon i cant remove the silicone and apply this stuff?
i still get a miss up high in the cooler night temps. i'm guessing gapping to 0.7 might fix this, but i'd rather keep 0.8mm gap if possible.
I have a different way of checking the coils, unbolt the coils, but leave them plugged in, wiht the car idling, preferrably in a poorly lit area, lift each coil with pliers by the plug, and watchand listen to the spark, if you can lift them 2cm without cousing a missfire, and can hear the spark(which will be pretty loud)then the coil and its insulation is fine.
Yeah im gonna give this a go tomorrow after work
Adriano that sounds a little dangerous. Make sure the pliers are insulated but I wouldn't recommend this.
There is so much Voltage around this area! Could seriously hurt you
Dont see how you can get hurt, the spark will always jump to the head if you pull it too far, the only time i wouldnt recommend it is if you are running CDI. That and i ve never heard of anyone getting hurt by secondary voltages on a non CDI ignition system, just gives a but of a buzz.
Edited by Adriano
You can get polyester resin from Bunnings. Its the same resin(gelcoat) they use for fiberglassing. Just go to the fiberglass section and get a small tin, some acetone for clean up and a good idea is some thin rubber gloves. Clean the coils down with the acetone to get rid of the carbon deposits. As to the silicon thats gonna be a tough one as the polyester resin wont stick to it at all. You MUST get it all of for it to work. Mineral turps or even Xylol/Xylene and a lot of rubbing with a cloth is best and again finish off with acetone. You will also need some small paint brushes that are NOT synthetic bristles as the styrene monomer in the polyester resin will melt them. Mix up the gelcoat as per instructions on the tin( best to do it in parts as it starts to go off in about 15 mins). Take you brush and start to dab a thin layer all over the body of the coil leaving out the plug area and of coarse the area where the rubber insulator goes over. I gave mine two coats just to be sure. If youve added the catylist (hardener) at the right ratio the it should start to go off in about 15-20mins and be touch dry. Try and put them in the sun for about an hour and they will achieve full cure.
That about covers it.
Edited by PLYNX
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
