I'd love to see some results and feedback on these.....but chances are no one's going to brave enough to slap these junk on their pride and joy, so we probably won't be seeing any results any time soon.
Is anyone here brave enough?
im hangin to see results, be a laugh if a few pp bought them n every1 started catchin and the price went threw the roof... n they alledge they use the same machines as Garrett how bad can it be? i mean if i jumped the counter at maccas and made a burger i dont think it would turn out a horrible mess...
Bought a cheap shit turbo a couple yrs ago of ebay and put it on my Ca 180sx, lasted about 5000k's then the oil seals completely seperated. All i can say is pay the bit extra for somthing decent...
Any workshop that uses ebay chinese t04e's on customer cars is dodgy I cannot stress enough how many shortcuts are taken to make them (low grade metals, poor balancing)
http://www.mx6.com/forums/showthread.php?t=110947
i PM'ed a guy on ebay about 1 of the afore mentioned turbos his response:
hey there yeah its a good quality t3 turbo it didnt bolt straight on to my r32 skyline i have to get a dump pipe with an external waste gate flange.ive taken the turbo to workshops who specialise in turbos they said it will have twice the power as my standard turbo an i will be able to run 25 pound boost.cant wait to give it a thrash lol.
Just to be sure, I hope no one is taking my above comment seriously.
As LBR33 stated STAY AWAY FROM THESE TURBOS! They are poorly made, and will almost surely damage something in your engine.
+1
The photos above i posted are from the turbo running for about 10 secs
This made me laugh.
i brought one of these, i did a little bit of research before i did, i thought nah ill be alright.
then before actually fitting it i did heaps of web searching and about 80% said stay the f**k away.
so i sold it and brought a garrett.
if you cant afford a good quality turbo(my 3040 was 2nd hand so i got it a lil cheaper anyway) just keep it stock or go hi-flow unless you want to be stuck with no car until you can get all the scrapnel out and afford a rebuild.
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
