Got these parts left of from stripping a R33 Series 1.
1. Spoiler up down $30
2. Hazard control $30
3. Electric Mirror control Switch $30
4. Rear Right interior $30
5. Rear Left interior $30
7. Dash Surround $50
8. Centre Dash part $150
9. Steering Wheel with boss kit $80
10. Steering column surround $50
11. Lower Dash part $50
12. Inside door surround $80
13. Right Left behind door $10
14. Seat belts front right, rear right, rear left. $100
15. Steering Rack $100
16. left window Glass $30
17. Pair of Front fenders. $150SOLD
18. Rear Bumper $50
All the above parts for $600
Cusco LSD $750 SOLD
Axpexi Coil overs to suit R33 GTR $600
Prices are negotiable if a few items are bought at the same time.
Edited by Geoff897
https://www.sau.com.au/forums/topic/189756-r33-parts-left-over/
does the light in the series 1 spoiler work? would you be willing to separate or if i sent you mine back so you have a complete spoiler? unless your happy to send the whole spoiler to townsville, NQ?
CUSCO LSD to suit an R32 Skyline in good condition. Set up as a 2way and can be changed to a 1.5 Way with the shims included.
It should fit into an R33 but you will need to check this your self as im not sure of the interchangeably of LSD diff centers.
LSD has done 20k to 30k.
Geoff
drivers side sun visor?
No sorry
Do you want the blanking plate or a switch to fill the hile?
Cat back has dents on it and everything probably has been punched out but you can have it for free or a 6pack or beer. pick up only
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
