I'm currently using a R34 smic. My tuner told me to upgrade to a front mount after the last tune. His exact words, "if this was my car, i wouldnt be using that intercooler"...."do it, its worth it"
I fitted the r34 smic a while ago, as an easy upgrade, and it made a nice difference. Thats when the car was making 185kw.
Last tune - 211rwkw on 11-12psi. Only mods are, full exhaust, pod, and unichip with boost module.
What are your experiences with fmic on stock r33 turbo?
Glad you did it? Regret it? Wasnt necessary?
EDIT:
I fitted the front mount and took it for a drive tonight. It's raining though, so nothing crazy. All seems good. I didnt notice any extra lag. It does make more noises now lol. And it seems to pull well, so no complaints there.
Just wondering if a tune is recommended after the install. My tuner told me i'd definately need one. I know it was a huge benefit after exhaust mods. So i'm pretty much planning on getting it tuned.
What are your experiences?
Edited by Munkyb0y
I have a FMIC on mine (stock turbo, POD, catback, ~8psi) and I noticed a mild but not insignificant increase in power since fitting it.
Id recommend it, the just jap kits are quite cheap too.
I used a blitz lm cooler, same side inlet outlet fitted well on the S2 GTST. Lots of trimming and cutting of intrusion bar and bumper bar was needed to make it fit well. As for performance did notice a bit of a power gain with stock gear boosted 12psi and 3" trust PE II turbo back exhaust with split dump pipe. Sounds great and does seem have more power. JUST DO IT!!!!! :closedeyes:
thanks for the replies. so far, you've confirmed what i was thinking :closedeyes:
With the money you spent on a uni-chip how come u didnt just get the apexi pfc or an ems system
the unichip was in the car when i got it. i thought about replacing it, but i found a tuner who knows these units well. he used to tune them for race teams when they were popular. i'm happy with the results. they are actually quite good if you get someone who knows what theyre doing.
Edited by Munkyb0y
Well anything over 200rwkw is a bit ambitious for the stock turbo in terms of results.
No-one ever backs them up with a decent mph on the 1/4 really. Most just bring home the usual 105/107 or so.
I really think the R34 factory side-mount will be enough.
There was someone who did a write up about a year ago to do with ducting it or something.
Cant remember exactly but there was a little bit extra in terms of keeping the cooler 'cool'. Got a few degree's which wasnt too bad
the r34 smic can handle at about 230kw atw.
If you are keen on holding onto the smic, look into water-spray kit for the smic.
http://www.mearcat.com.au/Kits/
by lowering the temps of the smic, this should allow you to gain more power.
Although, dont get caught with no water and a higher tune hehe
Thinking of installing the water-kit to my r34 smic on my r32.
Ive got the r34 ducting, and my front bar has an opening directly to the ducting, so it's as good as it gets in that respect.
i wouldnt bother going to that trouble. if it came down to that, i'd just go with the fmic.
what symptons would you see if the cooler wasnt up to the job?
these are the main reasons i'm considering the front mount:
- as far as i know, cooler intake temps make for a healthier/happier motor.
- consistency is another concern. sometimes it runs great, and other times it's a bit less great :D
- also, if the cooler is creating restriction, the turbo will be working harder to make the desired boost.
these are the reasons i wanted to avoid it:
- added lag? (not so sure about this one)
- wank factor (dress-ups rather than performance requirement)
- defect
i'll be going with a tube and fin for least restriction, with hopefully improved cooling.
Edited by Munkyb0y
lag is not that significant. So that isn't a big problem.
Maybe it's time to get an airbox for your pod filter :D
actually thats another bonus. fmic means i can set up a cold air feed to the pod through the unused hole for the factory cold pipe.
and at that stage, i'll partition the pod.
If at stock boost you will not gain top end with a FMIC over a R34 SMIC. Maybe over a R33 cooler you may gain like 5rwkw. You probably notice it more because there is a slight delay in the throttle response then you feel the power.
Such a waste going FMIC if on the stock turbo..plus you usually have to hack into your car a bit.
Edited by benl1981
Mate you get no power from a FMIC or R34...
the power gain is from the increase of boost
I think it makes sense that you DO get more power as the larger cooler is able to reduce intake temps at the 'same' boost level. Hence explaining rekins results and ones of my own.
+ me for the r34smic as i have 1 on my r32 aswell.I purely got it for the fact that it will let the air flow alot better
and because its slightly larger i guess thats beneficial in cooling.
i dont have a dyno sheet showing back to back smic install but i have 165rwkw.
With the stock turbo, the r34 smic is best option. 211rwkW is pretty decent for the mods you have and fmic will just add lag, wait until you do the turbo.
Take note of what Rekin has said and posted, he's the only one with supporting results.
    • I dunno about that as a blanket statement. Pitwork is Nissan's "Nissan genuine" thing, and for stuff like timing belts, I have found them to be excellent. Of course, for things like oil filters, you always use proper trusted brands anyway, not whatever the OEM has taken to using.
    • Ahhhh... If you were putting 12V to the led in there, that's likely made it very unhappy. Chances are how you put power, was 12V across an LED that's meant to only have about 20mA through it at peak, and a forward voltage of about 1.8 to 2.4 volts. That circuit is likely only a 3V3 circuit, and will have a resistor in series with the led too. That's my guesstimate on that light, without having touched one.
    • Another vote for installing them and see how you go.  I mean, you already own them, why would you not fit them?
    • I have had too many of those over the years, my cars have a toolkit or at minimum a cheapy multi tool thing because its too easy to be snookered by some stupid plastic clip that stops you checking the battery terminal isn't loose.
    • Basically, if there is a part# on the nissan catalogue, it is a genuine part. There is a thing called "new old stock" which is stuff made years ago but never sold (or landfilled), but it is super hit and miss what you can buy. Other than some expensive Nismo stuff there is nothing new being made that suits these cars. The only time to be a little careful is (mostly in the US I think, but maybe Japan too), Nissan started rebranding some cheap crap maintenance parts like oil filters as "Pitworks"; stay away from them, if you are buying cheap just buy whatever the local car parts shop carries The three part numbers have an explanation on Amayama: 0V005 is auto, base style 0V015 is manual 0V505 is auto, hectic momo branded ones, maximum F&F points there!
