Installed this a while back.
The installation was REALLY easy, alot easier than what I have read on here.
Basicly you had to grind off one nut hole off the exhaust manifold where the heat sheld screws to and every thing else just bolts up.
Stock oil lines hocked up perfect and I just blocked off the water lines.
I didn't need to bend the actuator rod like some people have said.
Here are the results.
https://www.sau.com.au/forums/topic/189849-kkr480-on-r33-gtst/
I also run a kkr480 on my rb25det and me and a mate installed it ourselves,
turbo bolted up perfect, just had to grind a bit of the exhaust manifold, oil lines bolted up, but i went into enzed and for $30 or so he put new ends on my water lines to match the same size thats on the turbo, then i just chopped the lines and used high pressure/heat hose 2 move them around to fit nicely, and towed car to my mech 2 get dumpipe fab'd up and cooler piping change a little,
comes on hard bout 4000-4500rpm, i just run actuator spring which is bout 1.2-1.3 bar of boost, bit hard 2 control boost in these things, only downside..
but worth every penny, ive done bout 5000-7000kms alredy on this turbo, runs like a dream
Yeah it has got a GMC or some Aus turbo reco company bandged on it. I dont think its GMC but that just comes in to mind, its some 3 letter name.
Yeah KKR480s aren't that big, this one came off my VS commodore V6 and that spooled it at 2800rpm for 12psi. Its around 3000rpm, well you feel the boost kick in hard as then look at revs and its doing around 3000rpm. will have to have a closer look.
Its definarly a KKR480 I brought it new.
Any way stock turbo isn't big enough because I want 300RWKW.
Also I did lean the living daylights out of it early on to help turbo spool.
Well not that lean like 13.7:1 Air Fuel Mixture.
Edited by Finny
Yeah I would get a boost controller if I was you, adjusting that actuator rod would be a nightmare.
I didn't think you could get 1.2-1.3 bar out of the stock actuator as my commodore running stock actuator on the KKR480 only saw 12psi tops.
Does it over boost at all in high revs? I am hoping I dont need to get the wastegate cut out so it flows more.
Ummm the enzed bit makes no sence... KKR480s are oil only.. I just blocked off my water lines. The stock oil lines seemed to bolt up perfectly.
finny mate, you sure got a 480 cause no way it would spool up that early and also if its a oil only turbo then what are the other two fitting in the turbo core for????. you might have a bitsa turbo cause every 480 ive seen has oil and water fittings
Also you will be very lucky to get your 300kws with a kkr480 they arent bigger enough for it.
Edited by nick81xd
:S
Mine is from JustJap its marked as a JJR480 but I thought they where just rebadged KKR480s... they look identical.
Maybe I am wrong.
It has only got oil holes.
ummm that sucks... I should have got one from otomoto :)
KKR 480 =
Yes I can see the water holes on that one
JJR480 =
Ohh well looks like I will be going to a Garret GT35/40 later on down the track then.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
    • I believe @Duncan has given it a crack at Mt Buller before (in actual race conditions)
