the shell is a 1993 r32 gts4 , in silver colour.
damage:
repairable write off, damage to front right side( where the guard wud be),
tiny dint in the rear side
items in blue is current sale price
the bare-ish shell comes with:
-bare drivers door $100
-rear bar $100
-gtst/gts4 fuel pump $50-70
-steering rack
-key
-ignition
-locks
-gts4/gtr attessa (sp?..lol) 4wd system
-body loom
bits that have been removed (other then things that can be unbolted):
-hand brake mount
-middle drive/tailshaft mount
-rear windscreen
-front windscreen
:spam:for $500
can add a gts4 rb20det for $1000
can throw in sum rear seats handbrake lines hubs brakes and various interior bits to sweeten the deal :spam:
extra info:
car was complied and on the road (has rego sticker, compliance plates, altho i rang up vic roads and they have no info on the car at all. so i was confused :closedeyes: )
i bought the car to use for sum parts so it wasn't on the road under my hands
so most likely a drift,drag or circuit car
cheers
-dan
Edited by Dan_J
https://www.sau.com.au/forums/topic/189857-1993-r32-gts4-shell-vic/
Seen the shell once...could u explain to me if the car is able to be put back on the road or not? becoz u said u called vic road and they didnt have any info on the car...so i was curious to noe the details
trade for a running auto S14 with cash my way? I'll even drive it down the street and roll your car away for you (you'll have to help push it up the street tho).
I have to come check your shell out one of these days... let me know when you're free.
  • 1 month later...
  • 3 months later...
  • 4 weeks later...
  • 2 months later...
  • 4 weeks later...
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
