as topic states. i have a sliding performance hiflow. non max oversize and she runs out of puff at 16psi on my 33 gtst
i thought they were rated to 19 psi?
im not very happy.
fixed the leaking plenum and runing 17...drops to 16 through the rev range. it dosent make any more power after 16.
only managed 231 rwk @ 16psi.
i have all the supporting mods too..injectors,z32afm...ect.
i was expecting alot more out of this turbo.
anyone else have this problem?
cheers
Edited by R33GOD
https://www.sau.com.au/forums/topic/189932-i-thought-slides-hiflows-hold-19psi/
  • Replies 46
it probably wont solve anything. im over spending money on power mods
just wanted to see if anyone has/ had the same problem with the turbo.
it is awesome to drive regardless of whats happening. i was just expecting more out of this turbo
I had the same probs... E-01 and all it would get to was 16-17psi... got it to 18 but ran out puff ... although I got 276 rwkw at the 18psi wringing its neck - ended up running around on 263rwkw @ 16-17psi...
Didn't worry about the lack of boost as I had reached the rwkw the turbo was rated at.... Since upgraded to a GT35R... Evil_weevil now has my old hi-flow!
16psi max seems a bit low for the turbo, thought youd be able to squeeze a cple more out of it. Ive got the same spec unit as you. being auto with piggybacks/stnd.injectors its about 40rwkw lower then yours at same boost. Mines got more in it tho.
bet you one thing tho - its bloody awesome on the street 'ey? if it aint broke dont fix it, or sell it and buy a name-brand item. for the price they are a good buy, understandable tho youd be pissed with the setup you have not being able to run that extra 1-2psi now and then. at the end of the day tho its just a power figure on a dyno, how it drives is another matter.......................................................
my Stagea is pretty much just nowfinished with the mods, very happy with my turbo choice selection. could have done better for twice the price but had a budget to stick to and will never regret using a Slide highflow. rounds off my overall package quite nicely.
i dont regret the turbo at all. just thought it had more in it. it spools up real quick and im happy with the power for the boost its at. but yea just wanted to run the maximum on it and squeeze more power out of it.
Edited by R33GOD
think im gonna take it back to him and run 13 psi again. i made close to 220 rwk on 13. least it will be safer :)
for the sake of 10-12rwk it'l be on 3 psi lesser, so meh
Edited by R33GOD
Hope you spoke to Aaron before questioning his products in forum?
i specifically said this isnt a flaming thread firstly.
i am satisfied on the performance if the turbo at this boost level and wanted to see if people with the same turbo had the same problem.
is freedom of speech not good for you?
what dump/front/cat/catback have you got?
custom bellmouth 3 inch front/dump stainless steel.
makes full boost by about 3400-3500 rpm.
i dont have a standard actuator, i have a hks one. the software in my ebc has been upgraded also
Edited by R33GOD
    • I think the concept is highlighting the various scenarios where thicker oil helps, and thicker oil potentially doesn't help and only generates heat and costs power, in turn for safety which isn't actually any safer (unless you're going real hot). If anything this does highlight why throwing Castrol 10w-60 for your track days is always a solid, safe bet.
    • Jason should have shown a real viscosity vs temp chart. All the grades have very little viscosity difference at full operating temperature.
    • Oops... I meant to include the connector  view... BR/W - power from fuse L/W - motor negative to fan control amp (and off to HVAC pin19) OR/B - PWM signal (from HVAC pin20) B --  ground
    • Yep, if you are applying filler it sounds like there is something wrong with the body lol. Safe to assume there is going to be a lot of sanding going on if your still applying fillers.  Picture a perfect bare metal panel, smooth as glass. You lay down your primer, it's perfect. (why are you going to sand it?) You lay down the colour and clear, it's perfect. No sanding at all took place and you've got a perfectly finished panel.  You won't be chasing your tail, sounds like you were prepping to start laying filler. If your happy with the body after the sanding, there is some bare metal exposed and some areas with primer, no issues at all, start laying the filler. You are safe to lay filler on bare metal or primer (of course check your technical data sheet as usual for what your filler is happy to adhere to).  This isn't a 100% correct statement. There is primer that is happy to adhere to smooth bare metal. There are fillers that are happy to adhere to smooth bare metal. Just make sure you're using the right materials for the job.  Typically if you are using filler, you would go primer, colour and clear. I've never seen any instances before where someone has laid colour over body filler (maybe this happens, but I haven't seen it before). So your plan sounds pretty normal to me.
    • I don't think there's any way someone is push starting this car.. I honestly can barely move it, and moving it and steering it is just flat out not possible. I'm sure it is, but needs a bigger man than me. I have a refurbished starter now. The starter man was quite clear and consise showing me how nothing inside a starter really should contribute to slow cranking, and turned out that for the most part... my starter was entirely fine. Still, some of the wear items were replaced and luckily it didn't show any signs of getting too hot, being unfit for use, etc. Which is 'good'. I also noticed the starter definitely sounded different, which is a bit odd considering nothing should have really changed there.... Removed and refit, and we'll pretend one of the manifold bolts didn't fully tighten up and is only "pretty" tight. GM only wants 18ft/lb anyway. I also found a way to properly get my analog wideband reading very slightly leaner than the serial wideband. There's Greg related reasons for this. The serial output is the absolute source of truth, but it is a total asshole to actually stay connected and needs a laptop. The analog input does not, and works with standalone datalogging. Previously the analog input read slightly richer, but if I am aiming at 12.7 I do not want one of the widebands to be saying 12.7 when the source of truth is 13.0. Now the source of truth will be 12.65 and the Analog Wideband will read 12.7. So when I tune to 12.7 it'll be ever so slightly safer. While messing with all of this and idling extensively I can confirm my car seems to restart better while hot now. I did add an old Skyline battery cable between the head and the body though, though now I really realise I should have chosen the frame. Maybe that's a future job. The internet would have you believe that this is caused by bad grounds. In finding out where my grounds actually were I found out the engine bay battery post actually goes to the engine, as well as a seperate one (from the post) to the body of the car. So now there's a third one making the Grounding Triangle which is now a thing. I also from extensive idling have this graph. Temperature (°C) Voltage (V) 85 1.59 80 1.74 75 1.94 70 2.1 65 2.33 60 2.56 55 2.78 50 2.98 45 3.23 40 3.51 35 3.75 30 4.00   Plotted it looks like this. Which is actually... pretty linear? I have not actually put the formula into HPTuners. I will have to re-engage brain and/or re-engage the people who wanted more data to magically do it for me. Tune should be good for the 30th!
