R33GOD, not sure if this is relevant.
I've got a slide high-flow too. It's the VG30 one though. Mine spools up quick and comes on real hard. On my 34, i'm pulling 240rwkw on just 12 psi. And that's on a piggy back ecu. Will be running more boost soon once i fix on either a motec M48 or power FC.
Understand how you feel mate, i would be disappointed if i can't have my turbo performing at its peak level. However, we all have to agree Aaron made hell of a good hi flow :)
  • Replies 46
definately a good turbo for a standard hiflow. guess i could miss out of a few kw by having a better spool up than most other brands.
And for the price i paid overall i am satisfied
well 2nd gear breaks traction at 80% throttle without droppin the clutch so im happy. And i got thick 265's on the rear :D
how do u find lag with the vg30 rear and when do u get fullboost by?
also spoke to the tuner today and told me that it made more torque than when it had 240rwk previously.
so im happier now. And damn it gets to speed quicker
Understand how you feel mate, i would be disappointed if i can't have my turbo performing at its peak level. However, we all have to agree Aaron made hell of a good hi flow :P
hey sloutch
what support mod are you running? to make 240 just wondering..
cheers
albert
i guess it will have to do for now. if i get bored with it il get a nice big turbo next yr. But what turbo to make the most out of my supporting mods...... :P
To get a bigger turbo you'll probably sacrifice response for top end power.
IMO, an upgrade from the hi-flow might be the HKS 2835 pro s which seems to be able to break the 300rwkw mark and not too much lag and it can be internal gated.
well 2nd gear breaks traction at 80% throttle without droppin the clutch so im happy. And i got thick 265's on the rear :P
I hit full boost at 12 psi at 3700 rpm.
Mods: full exhaust, fuel pump, fmic, pod, injectors. I guess the engine is pretty healthy, on my stock turbo, i made 210rwkw on just 10psi.
This may be a stupid question but where are you taking your boost reading from? If it is from the inlet plenum (standard location) it could be possible that the turbo is running at 19psi, and you simply have a few psi pressure drop across your intercooler, piping etc?
Just putting it out there you think it would of been better to go with say a hypergear turbo i got one myself sitting there waiting to go on and got mate with them on there cars and they are good will get you the numbers you wanted
since i got it tuned i personally havent driven it but was in the passanger seat. went better.
first time i took it for a drive yesterday and its sooo much more powerful and responsive than when it had 241rwk. i just couldnt believe how much better a car can go with less rwk. why is that? its got me puzzled
figured out how much peak torque it has too. 540nm torque at the fly :whistling:
Edited by R33GOD
could have a better torque curve, making it feel faster, but the most likely explanation is that you were sitting in the passenger seat, this always feels faster than driving
this is when i drove it for the first time a few days ago..
R33GOD - I just dropped my 33 off at Unigroup up here in Sydney.
Last time it was there they fitted the hi-flow and EBC.
Now Im going 550 injectors, z32 AFM and retune so I'll let you know how mine goes :)
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
