Hi All,
I had my standard r33 s2 turbo go west on Sunday. Both impellers disintergrated at once! I have pulled the old turbo out and am in the decision process of considering upgrading to something with mroe potential and newer design or hi-flowing the original.
Mods are as follows:
K&N Panel filter
3 in dump, High flow cat, trust 3 in cat back
GReddy Profec 2 boost controller
GReddy front mount kit (brand new as old one has impeller lodged in it)
Peoples opinions?
https://www.sau.com.au/forums/topic/190338-to-hi-flow-or-not-to-hi_flow/
looking to get somewhere in the region of 275rwkw. Car is used for street for the time being and probabl;y for the occasional track day (both grip and drift).
I drive in a bit of traffic every now and again so response is high on the list, but i can manage 3500 lag
be prepared to spend some serious cash if ur chasing 275 rwk. i very much doubt ul do it on a hiflow.
on the other hand if u set urself a goal of 250-260 you will get it on a hiflow with nice spool time.
set urself a goal of 250..least u know your conrods will be up to par
Edited by R33GOD
Cheers guys,
I might go for the Hi-Flow. I spose it also means that I wont have to upgrade fuel pump, injectors and computer if I keep the boost reasonable for the time being.
With the Hi-Flow, 3' dump (HI flow cat) and trust 3' cat back zorst, k&n panel filter, greddy FMIC, and GReddy boost controller I should be making round 200rwkw anyways hey?
about to load the skyline onto a trailer and take it down to screaming performance in wollongong (used to work there off and on). I think Daryl has a few options as to new turbos that will only require new oil and water lines and bolt onto the original manifold and dump pipe. Apparently they are more responsive as well.
I'll have it dynoed before it leaves the shop so I should know what power it makes.
$5 bucks to the person who can guess the rwkw figure right!
To add more info for people. I will be running the standard fuel system for the time being. So my guess is smack on 205rwkw... I will post the dyno sheet when the car is running! Make sure you have paypal accounts.
Oh man is upgrading fuel pump and injectors on the cards. I will run lower boost levels until I have saved up some more dosh to get the upgrades. I've already had to shell out for a new turbo, new hi flo cat and new intercooler. I took the more expensive option of buying a GReddy FMIC...
Are all FMIC the same? Was it worthwhile to buy a proper brand name cooler rather then a no name cooler
I doubt a brand name FMIC will impact performance at low boost; but at high boost the design is probably better for air flow (i'm not 100% on the design differences) but you're definitely getting a better quality product with GReddy and it'll last longer than that Home-Brand-made-in-China-crapola :whistling:
Let us know how the Hi-Flow goes...i was considering doing the same to my hammered stockie turbo.
I made 161rwkw with just a boost controller running 11.5psi. I have since then done the full hi flow exhaust, FMIC and air filter. Now with the hi-flow turbo I hope I should make round the 200rwkw mark.
    • Before starting any work, we attempted to adjust the tune. However even after adjusting it to certain extremes like completely stopping fuel, it had no effect. What fixed it was removing the Nistune Board and installing the original EPROM instead. This immediately fixed the issue. Everything should have been fine with the Nistune Board installation, so I am unsure why it has caused a problem. The soldered connector is also properly soldered. This worked when I first got the 550cc injectors, before cleaning, but that may have been a coincidence.  We ended up not installing the fuel pump hanger (at least for now). So currently running stock injectors, stock fuel pump, stock fuel pump hanger – Well everything stock except the exhaust. Now I have around €1400 in Nistune, Injectors, and Hanger collecting dust for the time being, perhaps I'll install them in the future. For now I'll enjoy the car as is 😁 Thanks a lot for all your assistance, I really appreciate all the help you have given me.
    • The turbo can’t be the issue. They’re proven to make much much power than you’re making. There is something in the setup that isn’t correct. - has the exhaust got any silly step downs? - what exhaust manifold?
    • Ok, just the way you wrote it made it look like you had the stagger the wrong way around
    • I was getting anxious with the DVLA not knowing if the paperwork is fine or not, so I rang them. No update had been given, but I  was reassured that providing the box was ticked on the V750 then the application will go through fine. I've been checking the DVLA website pretty much every day, in the hope that it would have been done. Fast forward to Monday 29th  and I was greeted with a new screen on the check, and it finally showed as Taxed and MOT'd, woohoo! The car was in desperate need of a clean, not knowing when this day was coming it was put off. As far as I was concerned I had another 3 weeks  I'm not normally one for using snow foam, but I wanted to give it another try It hasn't cleaned up too bad considering it's 21 years old and lived on a boat for a number of weeks. The personalised number plate is J2 XBK, an illegally spaced number plate would have it read J2X BK. BK could either represent  the colour black or Baker, which is my surname. I filmed the first drive, the Youtube link will be at the end. I used the same driving route I did with the 323F V6 when I had a new exhaust installed, heres a couple of photos A few more since then Youtube video can be viewed here: https://www.youtube.com/watch?v=TjkFHPzjGDw
