The Plan:
I needed somewhere to mount my new amp. I already have and amp in the car that drives my sub, but needed a neat way to mount the new amp to drive my 4 speakers. I was going to just mount it under the seat or something like that, but Ant (Arch6) convinced me to go all out and make a false boot floor. I wanted to keep the car as original looking as possible while having a functional install.
Current Setup:
Panasonic CQ-C9901 Headdeck driving 4x infiniti components
350W Alpine Amp Driving 8" Kicker Solo-Baric Square Sub
New Setup
Panasonic CQ-C9901
Rockford Fosgate P4004 driving 4x infiniti components
1 Farad Cap
I've includes plenty of photo's in-case anyone else is keen on doing this.
I still need to sand and paint the panels, so it's not quite done yet.
First, We put the car onto ramps to make the boot a nice working height that won't break out backs
This is my current setup. Amp on the left and sub on the right
Removing the bracing reveals...
Amp is mounted onto the side of the battery bay.
Amp Mount. The wires run under the amp and so all wires are nicely hidden. Probably goint to paint it black)
Next step was to make the mount for the Cap. Because there was no room and it was taller then the amp i had no choice but to mount it on top of the spare tyre.
The metal/wood plate that the Cap sits on it held in place by three very very strong magnets.
this way, if I do get a flat I just have to move the cap off the amp side and remove the spare tyre.
I could probably store some tools and my first aid kit on this side :D
Putting it all together
Bacause i'd raised the floor the factory carpet would no longer fit. So i had to get new carpet for the floor.
Cutting out the carpet.
Got the edge of the carpet overlocked at my local carpet place.
And we're done.
@The scissor jack can still be easily accessed even with the false floor.
@The rear struts can be removed without having to remove the lower level of the false floor.
@Total loss of boot volume is apprx 70 Litres (floor raised by approx 8.5cm)
@Total cost approx $90 for wood carpet etc..
@Took about 5 days to do (about 3 -4 hours a day) Ant and I spent alot of time leaning over the boot and staring aimlessly, pondering, day dreaming, :bored2dea :confused: etc.... Someone more focused could probably do it in a day :)
Edited by Fanta R33GTR
https://www.sau.com.au/forums/topic/190711-project-false-floor/
Ditto to the bracing! =-o
So, a question for you...
What supports the MDF in the middle (over the spare tyre)? I did a VERY similar setup but over time the floor started to sag horribly. Laptop, shopping... nothing majorly heavy went in there.
Also, how did you mount the MDF to the floor?
Cheers!
Cheers!
The middle MDF is supported on the left side by the amp base and on the right also by the false floor base. To stop it sagging I have run 2 pieces of 2cmx2cm square aluminium tubing along the backside of the middle piece (in the photo's you can see 2 lines of screws that run along the middle piece, these fix the aluminium to the mfd) You can put enough weight on this setup to push the suspension on the car down without any sag. I used 9mm MDF. The middle board clears the cap by about .5cm, no weight is supported by the cap.
Mounting the MDF to the boot floor without making any unreversible changes was a real challenge.
The left side (amp) - There are 2 bolts that come up throught the floor. They are holding up the heatsheild for the muffler. I replaced these bolts with longer ones to give me something to bolt the floor base to.
Right side - On this side also there are 2 small bolts that come up through the floor. These are not long enough to mount the board onto, so I made up a metal plate that bolts onto the existing bolts. The plate has longer bolts attached to it so I can mount the floor to it.
I know it sounds a little confusing.. i'll upload more pics to clarify tomorrow.
thats an awsome design man, just 1 question or thing id be orried about, how does the amp hold up without air around it. The reason I ask is cause ive had an amp catch fire before, it was a shit amp and not the best instalation (just got my licence, older and wiser now hopfully :) ) but it was placed under my drivers seat so i smelt it before anything bad could happen, and i thought mayby extra dust and lack of air circulating might have been a contributing factor.
thats an awsome design man, just 1 question or thing id be orried about, how does the amp hold up without air around it. The reason I ask is cause ive had an amp catch fire before, it was a shit amp and not the best instalation (just got my licence, older and wiser now hopfully :thanks: ) but it was placed under my drivers seat so i smelt it before anything bad could happen, and i thought mayby extra dust and lack of air circulating might have been a contributing factor.
Thats the reason why I went for a very well known brand of amp. The P4004 has a huge heatsink surface and plenty of heatsink mass. I've measured the temp, using a infared thermometer, after a 90min drive with the music pumping and the hottest part on the heatsink was only 32deg, so even in summer I don't expect the amp to get above 40deg.
I was initally going to go with the jaycar 100x4 amp, but it's more compact and runs much hotter.
Very impressive!
I want your original amp/sub setup you have there. What sub do you run? And what are the dimensions of the amp mounted next to the battery? How do you get it in and out?
The sub is an 8" Kicker square sub. It provides around th same punch as a 10" or 12". It's a dual coil sub so it's a little more expensive but needs less volume. the volume of the sub is around 30 litres and molded to fit around the computers in the boot.
The amp is a Alpine 350
Dimensions
Width 9.5 in.
Depth 10.5 in.
Height 2.31 in.
It's actaully really easy to get the sub and amp in and out (after you've undone the 20 or so bolts for all the rear bracing and struts) :thanks:
my bad, does it actually do any bracing? and is it transferrable to a GTS?
nice work on the false floor it looks stock, been meaning to do something like this.
That bracing does add a little stiffness, but is only a real advantage if your driving hard.
It won't straight into a GTS, but you may be able to modify it fit in. Not sure.
Ahhh... Nicely done!
So the square tubing (of which I have plenty!) is screwed to the MDF.... but stops before the edge? That overlap would sit on the raised sections of the amp and floor mounts, then get screwed in? No.. not screwed in? You couldn't get to your tyre if that was the case. Thanks for the explanation! (and good luck pulling those hard disk magnets off the spare!!!) =-D
  • 9 months later...
  • 4 months later...
  • 2 months later...
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
    • Can you also make sure the invoices on the box (And none exist in the boxes) are below our import duty limits... I jest, there's nothing I need to actually purchase and order in. (Unless you can find me a rear diff carrier, brand new, for stupidly cheap, that is for a Toyota Landcruiser, HZJ105R GXL, 2000 year model...)
