Then trying to find a gtr for 19k wont be easy
I don't know..
It wasn't that hard for me to go to the first page of the for sale section here to see this.
http://www.skylinesaustralia.com/forums/t174877.html
he is looking for trades too.
give him the $9K you have on top of your gtst.
best buy eva
I reckon stick with the original RB25 transplant, but plan to get the bottom end forged for over 260rwkw of power.
It's still gonna handle at least 300rwkw with the mods you want, and with some top end mods (cams/cam gears/v. springs/port&polish) will be able to make a lot of power.
So you'll save a bit on buying the 25 rather than a 26, and you're not going to be 'disadvantaged' that much with the end result.
Thats my 2c
So you recon you can buy and build a forged motor for $7k, well probably yes depending on parts, then you need the gearbox to back it up, then a fuel system, then management, clutch oh and maby a turbo setup too.....
point out an RB30/25 combo that cost less than a stock second hand complete rb26dett.
How about this one for ya? http://www.skylinesaustralia.com/forums/t1...66#entry3370166 I had a hand in building that engine, one of the best budget builds going around IMO. Had exactly the same setup sitting at home until I decided to sell my car, sold the engine to a mate for his VL.
ya wot?
plenty have sold recently for very low 20's that had had full engine rebuilds and turbo upgrades
you could check the online ads at the usual locations and buy any number of standard-ish ones for under well under $19k today if you wanted to
yeh I remember leighs RB30.
if you can do that then I can see how it's a cheaper alternative.
pretty much everyone can get $100 rb30 bottom ends.
not everyone has connections for $1000 GT30's.
$500 rb25de heads.
etc etc.
I say sell up.
and buy a ticket to brisbane.
then buy this.
http://www.carsales.com.au/used-cars/priva...x=mode+matchany
His a dweeb he doesn't have connections, he just shopped around on SAU and I think he is telling slight fibs concerning the turbo. Negotiate and you will be surprised, so long as you are willing to be flexible
RB25 head
http://www.skylinesaustralia.com/forums/t1...mp;hl=rb25+head
http://www.skylinesaustralia.com/forums/t1...mp;hl=rb25+head (I like this one personally)
Turbo
http://www.skylinesaustralia.com/forums/t1...tml&hl=gt30
http://www.skylinesaustralia.com/forums/t1...tml&hl=gt35
http://www.skylinesaustralia.com/forums/t1...tml&hl=td06
Or just stop being a pussy and get this engine:
http://www.skylinesaustralia.com/forums/t1...tml&hl=rb25
And this huffer:
Edited by ardie
Its an R32. IMO RB26's are far more friendly.
Another option Jason is you could get a front-cut. That would also net you brakes and so on, for not a lot more in price as front-cuts arent a lot more expensive that the motor/loom themselves.
Hell, even in my 1400kg car the RB26 wins over any motor setup i've had.
Admittadly i havent had a 30DET, but ive had a reasonable 30ET and it didnt do anything for me in a lighter car (VL)... but then with all my reasonable power builds (remember he is chasing power later) ive just bitten the bullet and done a full rebuild from the outset.
26 or 30det is each to thier own.
RB26 grabbed me for the sheer reason of all the legalities - you have NO issues what so ever.
Where 30DET's that use a RB25 head require a dirty big single and then it stands out like dogs balls.
Yeah, but then the turbo has let go which one can probably attribute to the building of the motor and related oil pressure.
So its not so budget when your wasting time with the car off the road due to reliability problems of a cheap build :P
Ummm actually, the engine is still running with another turbo on it. There was shit in the oil line. There is no issue with a "cheap build' here, its to do with Leigh being a stooge and not checking the lines
If you had driven a hybrid you would know that they are a totally different engine. The 26 still offers many advantages like I previously mentioned, but I still think that for the result, they are overpriced
Turbo could have also been a dodgy job, heard one of the previous owners was a dodgy rat.....hahaha jk jk
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
