  • Replies 49
hey guys when the battery light comes on while the car is running, it has nothin to do with the battery, it means there is a problem with the charing system, usually the alternator or wiring to alternator, i see alot of people do this mistake, just let us know how u go dude.
Mine was being a bit difficult a while ago and cutting out etc. Was really frustrating, turned out to be a dodgy AFM and crank angle sensor, try swap them out with a mates if u can and go for a decent drive and see if that rectifies it. Goodluck buddy
Hi
I am having the exact same problem too...I drive a 94 GTS-T. It will drive fine but all of a sudden whenever i press break the engine will just stop. It ususally happens when it's really hot, like when i drive in the evening it will run fine but in the afternoon it will stop more often.
Hi
Is it an instant stop? Or does it go down to idle then stall?
id say def not the coil packs mate..does the car start again straight after it stalls or do you have to leave it for a while..?..sounds like either the crank angle sensor or the ignition module.!
Mien does this when pulling up to a roundabout/lights corner and i am breaking/shifting down. Sometimes the revs will just drop lower than it should and it will die on me. When this starts to happen (usually after the car warms up it'll happen every now and then) the idle will become a little rougher
...aac valve sound like the problem? ill be taking it to a proper workshop soon i think, the last dickhead to touch my car charged me an arm and a leg for a major service and this problem still occurs :ermm:
...aac valve sound like the problem? ill be taking it to a proper workshop soon i think, the last dickhead to touch my car charged me an arm and a leg for a major service and this problem still occurs :(
Check over your intercooler piping before bringing it to any shop. It could be leaking and causing the stalling.
any advice to do this properly? I guess i have to take the front bar off and get right down there but how do i check for leaks accurately?
Just check over your piping clamps. See if they're all tight.
Hi Thanks for your response, sorry I was away so couldn't reply earlier. As soon as i press break it stalls...the engine stops.
I can start the car immedietely using the key or just using the 2nd gear.
common cause of stalling is an intake leak like an aftermarket blow-off valve or a loost intercooler clamp
common cause of cutting out when the engine is warm in the AFM
find out whether your car stalls or cuts out. if it cuts out, swap the AFM i guarantee you its the problem
all the cooler piping in the engine bay was fine, i couldnt get the plugs off the grille to get the front bar off to get right in there and underneath to check those clamps tho lol
i have no friends with skylines to test afm, think im just gonna have to bite the bullet and see a quality garage its breaking my heart
If you have working eyes and hands and can read english, you can fix the AFM issue for yourself.
http://www.skylinesaustralia.com/forums/Fi...p;hl=SOLDER+AFM
It'll cost you time and a about $30 for soldering iron and solder and sealant (if you don't already have any of those.)
there are pics and stright forward instrucitons of what to do.
anyone who buys a skyline should do a handful of things as part of the first service I think.
1.) new copper spark plugs gapged at 0.8mm
2.) tape up coil packs with good electrical tape (or buy that silicon shit for a bit more money)
3.) Clean AAC valve.
4.) Clean AFM
5.) Re-solder AFM internal points
6.) new nissan paper ai filter element for stock air box
these along with new oil and oil filter, new fuel filter, will see a brand new car in most instances... especially if you've just bought a stock or near stock skyline which is 10-19 years old.
it will cost you bugger all in the grand scheme of things and will probably solve many little bullshit issues these cars have.
MAte,
When it stalls, I can restart the car and it drives fine again...
UPDATE: after swapping the battery; I thought this fixed the problem but no good... although it happens a tad less, still occurs... I'll drive nicely and then a couple of hours later, it would stall... then I restart and it would work fine again....
I think it's the cranke senor and the ignition modulle or the AFM - I will bring this to either Chasers or Nismo Motors in a couple of weeks.... do you guys think this will be costly to fix AND would the mechanic know how to fix this?
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
