hey wat afc u got???
i thought of boughtin a power fc..but im not botherd either..i dont want to replace the stock ecu either..coz i only got a gtst..i got 243rwhp..so in kw's, dats lik 180..
so it cant b ur ecu..
my mods include..
3a racing pod,turbotech bleed valve @ 10psi, replica rs bov, front mount, splitfire coilpacks, re-gapped plugs to .65mm, HKS super drager cat-back exhaust, KYB damper adjustables coil-overs, apexi neo afc + tuned..
so yeah..i played around wit my afc alot..and im on my second tune already..lol
was using abit of fuel..so i lean out some settings..lik only to 0..lik i had some hi-throttle setting on +12 ??dont no y..so yeah..
and i run lik mid 13's to 14 flat..
plus i heard the stock nissan computer is really good!!
so i dont no..
dont think it would be ur ecu..
plus u got a upgrade turbo..
ur car probl. needs a beta tune?
or u gota problem somewer?
Edited by bumble_bee
https://www.sau.com.au/forums/topic/191261-please-remove/#findComment-3441420
my mods include..
so i dont no..
i have a manual safc, manual boost cont., splitfire coil pack, fmic, pod, 3inch dump and highflow cat to 3inch exahused, everything else is stock.
https://www.sau.com.au/forums/topic/191261-please-remove/#findComment-3441446
to run 180-190rwkw, i would want to have a aftermarket ecu or piggyback unit to keep everything under control.
I would also look at bigger injectors, as at 200rwkw you start to get close to 100% duty cycle, and possibly a better afm. (depending on what ecu you get, you might not require one).
if i was in your situation i would buy
Aftermarket ecu
electronic boost controller (if you haven't already got one)
free flowing 3" full exhaust.
550 injectors
But yeah the tuner is right by saying that a hiflow r33 turbo should be able to run more than 11psi. As the standard actuator on mine was able to hold 16psi.
with the mods i stated above, and a couple more, with my hiflow turbo i pushed 240rwkw on 16psi.
https://www.sau.com.au/forums/topic/191261-please-remove/#findComment-3441450
Aftermarket ecu
550 injectors
yeh i do plan to do all that, but dont have the cash right now. i only got the highflow turbo because i blow my stock one up and it was only 200 bucks more then another stock one(got it second hand cheap). im just hoping i can get by with what ive got for a month or 2 till i can afored the rest of the stuff i need. thanx mate.
https://www.sau.com.au/forums/topic/191261-please-remove/#findComment-3441470
yeah, could be anything
but looks lik afm, injectors, or ecu needs a good tune!
can u take it to another tuning place???
oh, check ur o2 sensor, i found on my second tune that mine died, so i replaced it myslef..
cost me $120 for a new gen. o2 sensor..
have u evan got a afc???
that would be the first piggyback system to get..
or evan an e-manage piggy unit..
https://www.sau.com.au/forums/topic/191261-please-remove/#findComment-3441482
i have a stock 33 gtst with just fmic, turbo back exhaust and boost controller set to 12psi and make 205rwkw....and power range is flat as a tack and runs a 13 flat....
so stock ecu, injectors, fuel pump can handle it....
https://www.sau.com.au/forums/topic/191261-please-remove/#findComment-3441491
Even the RB25 turbo on my RB30 is maxing the airflow meter just below 6000rpm.. I would guess that a hiflow on an RB25 is going to be maxing aswell.. if the ECU can't measure anymore air it can't throw in anymore fuel.. hence leaning out and pinging..
The stock ECU can only handle so much, if you start to go outside what it can measure/account for, then you need aftermarket management and bigger afm/injectors etc.
https://www.sau.com.au/forums/topic/191261-please-remove/#findComment-3441500
my mods include..
so i dont no..
man, what are you saying?????
with his mods, the standard computer is not really any good. He should be getting an aftermarket computer. Most likely he is hitting R & R, after the high flow install.
drifta: my advice is to make sure ur afm is not maxing out, check you coils/plugs and if the problem is not there, get an aftermarket ecu and then wind more boost into it. But then, you'd be looking to get bigger injectors and bigger afm.
Cheers
https://www.sau.com.au/forums/topic/191261-please-remove/#findComment-3441512
1. Get a decent ECU
2. Get a better AFM, or 1. with a map sensor
2. Get a decent Tune (from a new tuner, see comment below)
That will fix the problem.
Doing things 'on the cheap' im surprised you have not destroyed the motor already.
Pinging in the tune that is clearly heard... is a perfect example that the tuner should not be tuning. Its so sub-standard its not funny, so get a new tuner for the ECU setup
https://www.sau.com.au/forums/topic/191261-please-remove/#findComment-3441514
Cheers
hey check this out..
the stock ecu is good just needs to be tuned rit..
ive read many articles of people using the stock ecu upto 300rwhp..
here check this link out and read wat it says about the stock ecu..
http://speedworks.com.au/products/bikirom/bikimain.html
so he shouldnt hav a problem here...
https://www.sau.com.au/forums/topic/191261-please-remove/#findComment-3441551
13-14psi boost on a highflow is not at all the same as 13-14 stock. that is your only problem. for sure the ecu is getting afm signals which make it say "WTF??". turn the boost down and try again
ive had stock ecus pinging and retarding timing at 12psi and up on stock turbo. to attempt it with a highflow is a bit stupid without any other engine management
https://www.sau.com.au/forums/topic/191261-please-remove/#findComment-3441803
hey just from reading the original post it doesnt sound like an ecu issue. change the crank angle sensor on the front of the motor. that is more likely to be the issue, if that fails then good luck ,).
i would be almost certain thats the issue
dude i think your on the ball because my tuner said the same thing, he ran out of time to try it but its going bk tommorow so hopfully ur right. thanx mate.
https://www.sau.com.au/forums/topic/191261-please-remove/#findComment-3441853
    • Pressure when IDLING, is meant to be 51PSi... So that amperage value needs to go up a fair chunk... I'd personally be factoring for more like 12amp at least on those runs, and at that point you need to hope the already there wiring doesn't drop you a volt or two, as that's a lot of fuel pressure flow drop off from 13.5 to 12V! Taking idle pressure of 51psi, means the pump will be drawing a MINIMUM of 9amps all the time based on your reading of the graph (3bar base, then allowing an extra 0.5bar for boost = roughly 51psi)
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
