Link to quite possibly the gayest website known to mankind as far as linkable pages goes
ffs autotrader shits me up the wall. browse the Used Car categories, go to Nissan, then select the Skyline GT-R sub category, then scroll down till you see an R35.
If I ever meet anyone who claims to work for Auto Traders IT department I will give them a swift kick to the nuts before I carry on conversation.
so technically my vin no. would be rb25det?...shit guys we've been getting wrong this whole time...
btw its missing the part that says "mature lady owner, never been thrashed, always been garaged. genuine k's, regretful sale, as going overseas, starting new business, having a baby, getting married and getting a company car
foregot 'buying a house' and 'never modded'
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
