Dyno Day
67 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Hey ppls,
Due to other dyno days being held around the same time SA/SAU usual holds their the Annual SA/SAU Dyno day hasn't been held. Its great for a checkup of how the cars running and mix it up with a few other SAUer's.
DETAILS:
BOOSTWORX - 57 Boothby Street, Panorama
TIME: Saturday 8th of March - 10:00am :- So get there 10mins early POSTPONED
The cost of the dyno day is $30 for 2 dyno runs and a print out.
A BBQ and refreshments will be provided charged very reasonably per snag and drink
Please do note there has recently been a little hoon activity within the area (which is believed to be related to the TAFE); Boostworx has been targeted as the possible offender; so please no burnouts or hooning through the sidestreets.
The plan is it will also be the first day of accepting SA/SAU club memberships which will be cams affiliated.
No prizes etc as the dyno runs are provided at cost - Makes it fair for the near stockers.
There's no limits on what cars can be run on the dyno; bring your old banga for a laugh if you wish. As long as your an SAU thats all that matters.
So.... Who wishes have a run on the rollers on the day and possibly buying a snag or two?
01. Darkhorse - PAID
02. Vietorious - PAID
03. Salad - PAID
04. RB_Man - PAID
05. matty_31 - PAID
06. Nightcrawler - PAID
07. Dangerman4 - PAID
08. rd-runr - PAID
09. sambo33 - PAID
10. RB25DETS2 - PAID
11. 93R33 - PAID
12. wegs - PAID
13. J_Red33 - PAID
14. 180or200- PAID
15. Hotwire
16. Deluxe
17. AfterGlo
18 32_4whore
19. Heslo
20. Advent34
21. bezender
22. rad510
23. writeoff
24. dnbutts
25. AFTDRK
26. ryanrb25
27. gzilla
28. barricade
29. gtrkiet
30. natoe aka slw 031 - PENDING
31. SICKR33GTS-T- PENDING
32. Cubes - PAID
Now accepting payment to secure your place and choice of when you wish to run.
Remember its cooler in the morning. :P
We have the minimum 10 upfront payments to go ahead; if you wish to secure your spot and have a choice in when you wish to run get your payment in.
PM me for bank deposit
TIME: 8th of March 2008 - 10:00am so get there 10mins early.
AND FOR THE RESULTS...
https://www.sau.com.au/forums/topic/191361-sasau-30-dynobbqclub-day/
  • Replies 326
Posted Images
Will this be at Boostworx again? Is January an ideal time to run a dyno day? It will probably be pretty damn hot. I'd say April/May would be better although with current climate patterns - or lack there of - it may be cooler in January. I'd prefer the 19th as I usually have something on Australia Day.
Yes It will be at Boostworx again. Boostworx have the best price for a dyno day.
Myself I'm not too keen on spending $50 for a power run that some of the other dyno operators are charging when all you receive is a laminated dyno sheet with possibly a picture. GW does both 2wd and 4wd $40 and $50 respectively but $10 is $10.
I feel $30 is quite reasonable. A BBQ and Cold drinks will be available; Boostworx also has evap aircon so there will be plenty of air movement.
If the weather is possibly hot/warm it could be a really good time to hold a dyno day depending on how you look at it.
Its always good to have the car on the dyno during hot weather as you are able to find out how it runs in such conditions.
Is it pinging. Is it safe to give it a bit of a boot during hot weather?
So for those of you that don't have the car run up both in cold and hot weather it will be a good chance to see if the car is running well.
However... If the majority would like the day to be held a little later by all means it can be done. :P
I personally don't mind the idea of a warm dyno day as its a good check up.
    • Assuming the current ECU is stock, it might be worth getting hold of a nissan data scan cable. It could be as simple as voltage at the ECU
    • You need to test for spark when it matters - ie cranking. Kill the fuel supply, pull a plug and earth it, set up a camera and go crank. The spark needs to be consistent, every other turn of the engine. Not some sputtering of occasional spark. The reason I say this is because spinning the CAS in the air is not the same as spinning it installed, and if there is a bearing problem in it, the disk might work differently in the air than in the engine. You won't want to try to set the timing unless you know the spark is happening right.  Also, reconsider running the R35 coils against the stock ECU. They like a different amount of dwell cf the originals. It's not massive, you can actually run them, but it is better if you can adjust the dwell (which you can with Nistune in the stocker, or with an aftermarket ECU). Besides any of that - when you had the multimeter out, have you got power where it needs to be, earth where it needs to be (and when, in the case of igniter triggers), etc?
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
