a 1993 R32 GTST 179000 on the dial Suspension was installed at 170000, engine was installed a 171000 as was the clutch, and the turbo has covered less than 2000 km
R33 RB25DET
20 thou oversize forged pistons
forged h beam rods
reconditioned (new springs valves ect) and lightly ported head
N1 oil and water pumps
ACL race bearings
Cometic metal head gasket
ARP head studs and rod bolts
R33 Gearbox
R33 Differential
Garrett GT3076R Turbo
Tomei Poncams
600cc injectors
Z32AFM
HKS Hyper 3.5" exhaust with custom front pipe
Splitfire Coil Packs
OSgiken TS2BD twin plate clutch rebuilt by NPC
C’s Short Shifter
GFB Stealth FX Blow off valve
Bosch 700hp rated fuel pump
Apexi Pod Filter
Apexi PowerFC
Greddy Profec B spec 2 Boost controller
Custom FMIC
Custom intake piping
Oil cooler and filter relocation kit
Suspension and Braking
HKS Hypermax 2 coil over suspension
Front and rear strut bars
B pillar Brace
After market sway bars
JIC adjustable castor rods
JIC adjustable upper arms
Whiteline Pineapples
R33 GTR Brembos with DBA 5000 rotors
Front: 17 X 8 wheels with 235/40 semislicks
Rear: 17 X 9 wheels with 255/40 semislicks
Exterior and interior
Full respray- Custom Blue
Genuine GTR Bonnet and Grill, Front bar, and rear spoiler
GTST Type M side skirts
GTST Type M rear pods
Genuine R32 GTR Front and Rear seats
Genuine R32 GTR Door trims
Genuine R32 GTR Headlights
Nismo Gearknob
Audio
DVD player with 4 inch screen
6.5" Jensons in the back and JL 6" Splits @ the front
Last tune was a very safe 260rwkw it was making 300rwkw previously but it was not safe, a safe 300rwkw is only a thicker head gasket away! At 260rwkw this thing still really hauls and handles beautifly too as it has that little bit of extra attention paid to the suspension
I am asking 24,000 neg. this price is mostly designed to ward off dreamers and tyre kickers, if you are interested we will talk! I have included a picture of the car with 18inch starcorp impuls, if the buyer perfers these wheels could go on the car instead as I still have them at home.
PM me to discuss the car. Hope to hear from you soon!
Andy
OFFERS AROUND 20K WILL GET YOU THIS CAR TODAY!!
https://www.sau.com.au/forums/topic/191365-1993-r32-gtst-with-rb25/
Thanks for the kind comments guys! It will be sad to see her go after all the blood sweat and tears but after the best part of 2 years i am ready for a change!
my kind of no bullshit car!
ive never seen it... shooooooooooow me.
you could but it and see it all the time :ninja: ha ha I will even give you a special members price :)
someone buy this car.....this is an awesomely kept and run car has everything you need and nothing to put in except fuel...
I have been in this car and its a wet dream on wheels.
  • 1 month later...
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
