  • Replies 101
Bring the Datto! I bet there has never been 2 1200's at an SAU deca before!
Good point, I chose the Datto, it will provide plenty of body roll and oversteer haha!
Entry form has been emailed to you Snowy.
Thanks
Malcolm and i may need to drop out, will confirm next week :dry:
Sump arrived and needs to be sent back; so another 1-2 weeks before engine is fully assembled, leaving only two weeks for installation, fabrication, light tune, bedding in, retune, suspension work/alignment, etc.
Very sorry (and upset) to say that Mal and i have to pull, as the car will not be ready; Thanks to a certain business in NSW that believes steel grinding filings, rust and paint in a sump should not be cleaned out thoroughly before assembly and delivery!!!!! :P
NOT FARKEN HAPPY! :teehee:
Very sorry (and upset) to say that Mal and i have to pull, as the car will not be ready; Thanks to a certain business in NSW that believes steel grinding filings, rust and paint in a sump should not be cleaned out thoroughly before assembly and delivery!!!!! :D
NOT FARKEN HAPPY! :P
one mans loss is another mans gain! bl AL
paid and faxed for myself and nathan, hope we made it in time.
Troy.
yep no worries. Just a quick question - are you sharing the same car or are they seperate 1600's? (I just need to know for running orders)
Very sorry (and upset) to say that Mal and i have to pull, as the car will not be ready; Thanks to a certain business in NSW that believes steel grinding filings, rust and paint in a sump should not be cleaned out thoroughly before assembly and delivery!!!!! :happy:
NOT FARKEN HAPPY! :thumbsup:
geez Al I hope thats not the same manufacturer who I got my sump from... mine looked okay though *gulp*
pm me the brand if you don't mind
sucks we won't see the red beast at DECA:(
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
