Excellent turn out for the night thanks to everyone who behaved themselves. Lol.. @ those idiot kids trying to get people to do burnouts..
Hope everyone had a good time.
I saw those guys as i was leaving but i thought it was people from our group just acting up... hahaha they looked like monkeys... oooo cmon ripiiittt cmon.. i drowned them out with DA HORN
THANX TO EVERYONE FOR SHOWING UP AND HELP MAKE IT A REALLY GOOD NIGHT OUT.. (except for you know who)..
pics? :D
  • Replies 367
Posted Images
Big Thanks to all who organised last night it was great turnout :) and it great to have so many imports paying a visit to the Northern Beaches :)!
The only thing I was disappointed about was that Nub who cut sik out the front of Lucky and Pep's :(:D
Thats not cool to draw that much attention in your own backyard! :(
Edited by phillb
fun time had by all last night.
Jon, i got to talkin to a few people, and when I got back you guys were gone. Another time :D
I'll post some pics, although I didn't get that many good ones at all. Lighting was shit, I didn't have the tripod, and my flash had sweet f a worth of battery life.
Good to meet a few of the new kids as well.
I had a great night! topped off with a nice drive back along mc carrs and bobbin head with sam. such a nice cruising route!
Apart from that dude in the silver 33 everyone was fairly well behaved :)
Thanks for organising Marsss and Sasha! :)
p.s. sasha where did you disappear to? :domokun:
Damn - i didnt see you there!
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
