  • Replies 79
Hey guys,
i picked up the wheels from chris yesterday, great bloke to deal with and had everything ready wen i got there! Definately a good bloke to deal with.
Cheers
Jared
i paid for the sidemount n something else last week and still no reply from you. I pm'ed you 2wice, have you sent the stuff or am i getting jibbed here...
Hey mate,
If you are seperating this stuff, can you give me a price for;
  • Handbrake lever and cable
  • Pedalbox (clutch, acc & brake)
  • Clutch master and slave cylinders
PM sent mate
Replied
Do you have the exhaust manifold for sale still?
Sorry mate I sold the exh manifold along with the engine
hey mate if you r interested in seperating the 5 speed conversion how much for just box pm me price thanks
Pm sent
have you got the thermo fan that sits in front of the aircon radiator?
Pm sent!
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
