I was just taking it easy.. there were too many wankers out last night. People trying to race me in the pouring rain.. Phucking retards I swear. :P
And they wonder why cops are out chasing them when they try to race in conditions like last night.
I didnt! I cant believe I didnt either :rofl: Normally I keep my eyes peeled for other imports :) I did see another white R34 pulling into BWCP as we were leaving though, I gave him the thumbs up, but didn't get a response :) There were 3 R34s in line behind me tho, so must have been a sight :)
Saw this mental looking R34 GTR V-Spec 2 NUR edition in a car park in the city about 2 months ago. Grabbed these 2 shots from my phone:
Thing had a Nismo carbon fibre bonnet, among other things I can't remember. It looked crazy though, and very fast :rofl:
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
