Afro, before the building u work at was there i had a the guys next door bulldose a flat dirt track for me where your building is now, and used to go drifting in my go kart every day after school and all day everyday on the school holidays, haha, thats going back like 10 years or so.. haha
sweeet
what sort did u have? like a full on buggy one?
i had one too,, recently sold it, few months back,,
ya its fun when u can thrash it and not worry about breaking anything,, lolll
i think i saw the rodeo out the front.. is it the silver one?
saw a nice R33 2 door on kessels road gave a wae to the owner nice car dude !.. p.s i dont own a 4 door anymore same plates late 95 R33 2 door silver hope to see more liners out there
Passed a black 33 and a gunmetal grey 32, 32's plates were 00uch, about 8:15pm, southbound on the gateway. Caught up to them just before the shell.
They were travelling in a pack which consisted of an s14, and a wrx.
Gave them a wave, they went through the tolls and then musta been driving very slowly because I lost them very quickly, or they were just trying to get away from the striped beast :)
afro ? are you Afraz by any chance from mansfield ? or went to mansfield high ?? i see you around on seventeen mile platting road sometimes when im out that way..
LOLLL
ya dude,, i did!!!!
lol
were u one yr below me??
ya i live near miles platting road, and sometimes go along seventeen miles rocks road,,,
havent seen ur car yet,, gotta meet up one of these days dude,,
Hello everyone I'm Jade. Have not yet recevied my 32 but will have it in 16 days and very much counting.
You will prob see me the first Sat night of July as I will be doing the 48 hour run in process going from Surfers to Bris and back again : ).
So if you see me (you wont be able to miss the little 18 yr old girl will her new skyline, can't wait) give me a shout.
LOL. welcome.
If I were you I'd post up that you allready have a boyfriend (even if you don't) or all the "hardcore fully sick" little 20yo single boys on here with their shopping trolley wings will inundate you with pm's asking you if you want to cruise with them and the I'm looking for a fully sick skyline chick rot.
Either way, I hope you enjoy your stay.
LOL.  welcome.
lol good one. Is it rare for an 18yr old chick to have a skyline or something??
(love the shopping trolley bit) mine has a little wing too you know, I am not a fan of the wings so it will be ripped off as soon as it is here.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
