12ZAC - saw him when i left home for work, had a chat at the lights... nice car buddy
cheers mate, was heading to work from my girlfriends house, nice 33 yours is too! , lots cleaner than mine :P love those rims!
Lots of skylines driving home tonight:
I squeezed my butt in behind so_tred, (white R34 GTT JDM34) before the gateway tolls.
A black R31 passage gt having better luck with traffic than me going south over the bridge.
A maroon R33 heading south just before the bridge.
A unlucky white R33 stuck behind an accident further north on the gateway, heading south
Edited by HackerX
Spottred this morning around 7:50 - 8:10 in redcliffe a burgandy r33 plates, 919 GUQ i think, nice looking car, except, did u know your repco universal fit metal spoiler is not level? Your drivers side is like 3 inches high than the passengers.
This is for the fully sick drifting effect, you know like the funny cars.
snap!! that was me! i saw you. hot 34 dude, i want one!
Your 33 looks very clean.. :devil:
Spotted you too :)
Edited by so_tred
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
