Spotted RYN26 black 32 in St Lucia about 1pm today, i was heading the other way in my white 31.
And GTR 1 Bayside blue 34 GTR at the Shell servo on Lutwyche road windsor about 7 - 7.30 tonight
Logan mwy to Ipswich hwy/ Warego hwy turn off- Burgundy R32 2DR "527 JMB".
Had SAU sticker on back window above wiper motor.
I was in the wife's Dark Green R32 4DR GTS4 with SA plates "MYGTS4".
Tim Wagamama and his better half, a very nice couple that i met today at the charity cruise own a 34 like that i think. they live mnorthside of brissy.
ill second that. very top bloke ur car is amazing nice. hope u enjoyed our company and the second time round is more fun when u get to knw us.. :)
yeah thats it.
Awesome car,
mad couple
ta for the sunscreen buddy!!
lol white boy needed sunscreen.. ;)
spotted many familiar faces at the charity cruise today.. :)
Edited by markimak
yeah thats it.
Awesome car,
mad couple
Mad? Believe it! :P
I'd better leave that bottle of sunscreen in the car eh? :w00t:
lol white boy needed sunscreen.. :)
First time is always the hardest. :)
Hi everyone,
Good to put some faces to the forum names.
Cheers for chatting on Sunday.....but where were the cupcakes???
Tim
lol white boy needed sunscreen.. :D
yeah cause i am not black
Mad? Believe it! :(
I'd better leave that bottle of sunscreen in the car eh? :rofl:
First time is always the hardest. :spank:
Hi everyone,
Tim
yep completely, you own a skyline dont you :banana:
i think i will bring my sombrero next time.
yeah i know she skimped out on the cupcakes damn you Anna!!!!!
P.S. Stopped an r33 on sunday arvo, i was in 57IGG. saw you near the Pac Fair buddy...nice backfire....but preferably not next to the drivers door next time buddy.
Edited by Oblivion
yeh i gots me a racoon tan!
good to see you all out!
check out the photos here if you have not already - Oblivion there are 57IGG shots!
http://www.skylinesaustralia.com/forums/in...t&p=3337060
spotted a black r32 GTR heading into redcliffe from hornibrook bridge
also spotted nismo? white r34 sedan heading into redcliffe on the hornibrook bridge around 1.45ish
i was in teh Jeep grand cherokee :P
i was in teh Jeep grand cherokee :)
yup dat was me! I hate the hornibrook bridge!!! >_<
Yeah I saw you the other day also...nfi where it was though
I think I saw you on Main St Kangaroo Point (near the Pineapple hotel) last thursday(?) night.
It was pissing down rain tho...
Tim
