spotted JDM34 today on lytton rd at the traffic lights at the end of creek road....i was going to wave, but i was driving the hilux so you prob would have been like..."He's gay!!" so i didnt.
noice car!
Is that your new car??
if it is...
Awesome looking beast, mags suit it really well...and the colour...mmm....can i rub it?
OH and spotted a red r33 on creek road yesterday arvo about 5:30ish.
nice red and black mags.
Spotted a blue 32 that looked very much like Bunta's car in a very very rural setting last night. Some hot looking chic driving it with what looked like bunta in the passenger seat. Whats up with that!!!!!
Spotted AFRO8 Bayside Blue 34 this morning on ippy motorway around 8.30am. I was in my shitbox daily driver, the mighty rolla :closedeyes:
And i think i'm in love with Choyda's new ride (in his sig)... That looks hot mate!!!!
noice car!
I saw you in the lux the other day, and you didnt bloody wave. I DID! So I looked like a fool.
how else am I going to tune it in 4th gear?
Spotted AFRO8 Bayside Blue 34 this morning on ippy motorway around 8.30am. I was in my shitbox daily driver, the mighty rolla :w00t:
should have waved!! :domokun:
oh well , next time, :w00t:
Spotted Tiffany (51PRY) on Logan Rd on Tuesday night u-turning on Logan Road. Drove side by side with a de-badged grey 32GTR through the city last night too.
Hey Damo! I saw you pass me too! :domokun:
......it looks & sounds sex!
bahahah....yeah prob was tryin to kept it on the road...its real hard to keep straight, or maybe thats just me....where was i??
spotted a black r32 on ipswitch rd heading south at about 6:50 tonight....was to far back to see plates etc.
sounds hot though.
Spotted a very cute boy washing his silver Stagea at the car wash on Beaudesert Road in Acacia ridge. I didn't wave because I stalled and was cranky. Then embarrassed. Then Shy. But hello anyway!1
lmao...Anna shy?? couldnt be..
Spotted white r33 on creek road about 12:00 today...i was in red rooter....nice BOV sound :unsure:
Spotted dark/black R34 GTR with plates: 'CHOY' - (I'd assume it's CHOYDA's)....in the Valley last night around 6pm
One nice looking car.....
Edited by tim_wagamama
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
