spotted R34 GT-T with plates R34 GTT at slacks creek autobarn... waved no reply back :D....
Hmmm......I've got R34 GTT plates, but don't remember going to Slacks Creek Autobarn.....sorry dude! Were they QLD plates? what color was the car?
spotted heaps of liners today on my travels
White 33-ORG33 at arudal plaza with RID35 plate on the parcel shelf, obviously a chicks car with all the pink toys in it.
Blue 4door at Repco on brissy road-NSW plates
Blue 4door on gold coast highway in surfers-051 *** (two hot as chicks in the front!!!)
White 34 i flashed at and got weird looks-didnt get the plate.
A yellow 34 like vish's sitting outside "wheels that work" on ferry road-IM NOT were the plates (not what???)
Spotted Rohan today in his Brothers lux. First time we have actually spotted each other at the same time!
bahaha mad dude!!!
was that Chevelle playing?? :thumbsup:
Spotted a red 33 in garden city tonight...i think he was tryin to turn somewhere....
i was walking to me car.....
Spotted a R34 with number plates NISMO1 on the freeway around loganholme heading towards to city. All I can say is that car is sex on wheels. Gave a wave but I don't think they saw me waving.
tested the 'skyline owners wave' today going for a mock cruise through surfers (so my tatted mate can yell sleazey/wog/islander comments at people)....
spotted a couple of lines today in surfers - super hot 34GTR asian dude driving it - i let him in on the roundabout and he waved back
another white 33GTST but the tool didn't wave (he looked like one of those angry guys who's never been with a girl - you know the type)
oh and another white 33GTST with pink bits (:() on the interior and a blondey driving - think she gave a smile after seeing i was waving - too bad i had just got the third or 4th worst haircut ever today...
Spotted Noy this arvo near Bunnings Carseldine...
Had to high beam him to get his attention, lucky tho cause the cops were just down the road also another 500 metres...
So I was saying Hi to you, and in the process preventing all those around you from getting tickets... :(
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
