spotted yesterday, a white r33 on the southside in wynum / morningside aqrea haeading to the storey bridge. had bomex front bumper and the biggest spoiler i think ive ever seen, it looked to be the same higeght as the roof, sorta like a massive series 2 rear spoiler lol
also spotted a silver r33 today heading towards samford around 6;00 near albany creek, had sau stickers on side window
Spotted Tim (Wagamama)'s sexy blue 34 (34 GTT) on Ipswich Road near the Buranda Plaza at around 12.45pm today. I was in my u13 bluey sss (NIZ013) at the set of lights waiting to turn right to head into the city. Would've waved, but didn't see you until the last second and figured you wouldn't recognise the bluey anyways. :D
Spotted Tim (Wagamama)'s sexy blue 34 (34 GTT) on Ipswich Road near the Buranda Plaza at around 12.45pm today. I was in my u13 bluey sss (NIZ013) at the set of lights waiting to turn right to head into the city. Would've waved, but didn't see you until the last second and figured you wouldn't recognise the bluey anyways. :P
Woo hoo!!!! hit the horn next time!
Spotted a white 4dr 34 driving out of stafford city shopping centre, had two SAU stickers on the rear window. I was walking back over to the bowls club to get back on the amber fluid.
Spotted Lee (LBR33) on the platform at his place of work, Indro Station. Looking totally bored. Waved several times from across the road at Cold Rock but he didn't see me. Wasn't in my car... funny that. But this was my destination on Friday night when it went bang...
Ice Cream was good though...
spotted on saturday, i think a silver r34 coupe, with what i think was a gtr front bumper or something, driving along sandgate road around7ish looked nice as.
also, i have spotted a white r34 thats always parked outside in mango hill estate (not nort lakes) anyon on here?
spotted a sxc black 32 last night on anzac around 11.30, licence was.. 51ozz i think..and also one this morning heading on snook street. had a purple licence plate, don't member what tho.. both looked aweosme,!
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
