Spotted black R33 (s1) with the rear soiler cut off number plate HOT04 or some death, definatly had a H and an 04 in it. Cannon on the back, young guy driving. Going past JB HI-FI on Gympie Road about 11:30am-12:00
going out of nambour today saw a black r32? with white rims.... i was zoomen out of nambour i waved i saw sau stickers so it was some 1 here lol i think
was in a red r31 with blue bonnet :D
Edited by red_screamer
spotted this heading under the Ipswich motorway, towards the Goodna RSL tuesday morning.
Anyone know who's it is, It's got some rear pods that i'm wanting
Yeah he works at Toowong Smash on Sylvan Rd. He was selling it tho, like a few months back, haven't seen it since. So im guessing someone bought it?
Hey all
I'm new to the forums, had my R34 for exactly a week now =] Thought this would be a good place to make my first post.
I have a Silver R34 25GT 4 Door (factory standard), there's a couple of Silver R34s very similar near where I work, Coopers Plains, not sure if they're on this forum though.
I see quite a few Skylines travelling between Coopers and Mt Gravatt, always look to see if I get a wave :)
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
