Spotted John in a brand spanking new V35 Luxo sedan @ Kangaroo point ! Looks amazing would love to have a closer look
Spotted RDY60 Marki acting silly @ autobarn Macgegor :D
Also spotted 47GTR R33 GTR which was sadly slow as a snail on boost ... :) could need some TLC
spotted 87.MAT R33 GTR S3 near autobarn macgregor gave a wave got a death stare ... reason why its not worth waving these days
LOL was that the white S3 GTR? He gave me a WTF look too! hahaha
Ran into Vish too!
Spotted in Brisvegas CBD, Satuday night around 7 - 9pm:
R32 Maroon GTS-T exhuast & neat.
R33 Black GTS-T who couldn't resist revving it sitting behind my GTR at the lights.
R33 Silver GTR with hugeish white 5 spoke rims about a foot wide.
Anybody members here ?
-d3fo.
Spotted last Thursday arvo, NIZ035 - black V35, on Compton Rd, pulled over in front of the van that had caught on fire.
Also spotted 34 GTZ, black 34 coupe on the M1 on Thursday arvo.
I was driving the bf's 51CAS chaser...
probably there is a good majority of people that drive skylines but don't come on this forum, and think you're a homo or something for waving at them
Edited by mystery_kid
R33 GT-R dark purple/black... on Old Cleveland Rd heading into Capalaba.
Black R34 GT-T with Gold Rims Heading towards the City on Old Cleveland Rd.
Near Maccas/Shell
Edited by Owgasm
Spotted wha13 at wow in maroochydore this morning, also a white R33 2 door at the same time.
Spotted another white R33 2 door at harvey norman in kawana (i was the white 34 parked next to you). I think it might have been a chick that owned it.
last weekend or weekend just gone group of skylines up in montville few r33's and 1 or 2 r32's? and i think 1 supra? dunno if u was there... but lets just say i liked the sound haha and also
spotted a white r33 that was going up razor back... ?? my mate was driving my r31 :thumbsup: ur turbo or something musta be in-need of a rebuild? :)
spotted lOSTT 33' on hamilton rd next to westfield chermside at the lights, seen the SAU sticker on the side, i was in the company car.. was at about 3pm
I was at the intersection at the exact time in the SS...
Small world...
saw sweet orange 33 in mackay hell good kit caught up behind ya did ya see side of my car round that corner :action-smiley-069: anywaz consider ur self important cus i always tell people a hate 33 just cus there every second car i see now days.catch ya round
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
