Spotted a metallic grey r32 Gtr parked next to a white r33 Gts-T both with Sau stickers on side skirts on both parked on front lawn in Kennedy Dr Tweed...........Oh that would me with my mates Gtr parked next to mine. lol :laughing-smiley-014: :laughing-smiley-014: :laughing-smiley-014: :laughing-smiley-014: :laughing-smiley-014:
spotted LEE (phatoboi) parked on nudgee road today
and then spotted nismo (guy with the white r34 sedan, plates Blacks or something) at kippa ring shops around 4
ditto and ditto spotted both also
also spotted bryn nar newport... :D
also spotted a grey R32 with no number plates on the side of the bruce hwy at the strathpine exit looked like a little damage to the front right hand guard also...
lastlly spotted an r33 gtr at the airport (australia iar express) depot tonight at about 7:30pm
Nup...wasn't me...I was at Kippa Ring shops on Monday arvo.
Spotted gunmetal grey 33 tonight on the SE freeway heading south...had an Sau Sticker on the rear quarter window...nice ride! :D
Spotted gunmetal grey 33 tonight on the SE freeway heading south...had an Sau Sticker on the rear quarter window...nice ride! :(
oh wow, car looked identical to yours, had those black with the chrome lip rims, like i could have sworn it was urs, identical :)
althose spotted today around 2;30 on toombul road a blonde chick driving a white r32 gtr
i sware i see sunnycoast's black 34 coming up mons road this arvo round 3.45!?? was it you chris?
You wouldn't have seen me, I was in a ute! Though u would of driven right past my car parked on corner of william and burnett st.
It was me!!! I've been spotten! hehe. What were you doing up there again? See your car on william allot.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
