saw a maroon r32 with r33 gtst brakes at uni the other day plates nsn***?? anyone on here had SAU stickers!!
Thats Ben (Destero). I saw him as well. managed to catch up and have a chat before I had to run.
My GF parked next to an orange R32 at pac fair last night with a MASSIVE decepticon sticker on the back window, she felt the need to call me and inform me of how awesome it was, and that i should buy another transformers sticker for my car :S (had an autobot one on my previous car, that my dad now drives - he still doesn't know what it means).
She showed me pics, nice car whoever it is.
Also went and saw shutter last night, and when i was leaving there was a white R32 parked near my car too, in the upstairs section of pac fair, outside movies.
sore a black 33 4 door on beudesert rd around 12:15 today, and "53XYN" (think thats how it was done) yellow 34 at autobahn aswell today was in my black 32 gtst (the really dirty one lol)
Edited by ORIGIN
spotted a silver r34 4 door with no wing at the villa last night. said i liked his car and he said i liked mine. but god it was nice :)
ah, so that was you :blink: sorry i didn't stop and chat - was continuing on down to brisbane and was in a bit of a rush.
nice 33 your one is :blink:
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
