Just went to lunch witht he boss and saw 3 skylines.
1st: White R33 parked in the nerang Bunnings carpark, next to a silvia. Had what looked like exhaust marks on the rear bumper? I wasn't up close so couldn't really tell.
2nd: As we were going to the nerang subway (so this is like 20 seconds after i saw the ffirst, for those who know nerang) a cute blonde in an aqua-ish S2 R33 pulled up as we were. I said hey in subway :D
3rd: As we were sitting down, a white R33 GTR went past the road that goes along the highway.
Was there a meet in nerang or something? :S
Spotted 2 mroe tonight (i was on fire today or something).
White R33 GTR on the M1 at tweed, you had bright lights lol, we came along side you and gave u thumbs up, but i duno, it was cycloning outside.
Also saw a parked white R32 in coolangatta, couldnt make out any details/plates though.
okay, spotte3d a white r33 series 2, wth front bumper smashed up at aroudn 4;30 on gympie road lawnton around/
then had a greenish blue r33 series 1 following me form norhtalkes to rothwell round about around 4;45, then saw a white r33 series 2 on the rothwell round about heading into dbay,
then saw a white series one at harvey norman parking lot,.
then saw a white r33 series 2 parked on side street opposite hecrules road school.
alot of white r33 in 20 mintues lol
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
