Stopped at an intersection near my place in Springfield and a car almost identical to mine comes around the corner past me. I had the window down ready and said, quite loudly, "nice car mate!!"
He looked at me like I was from another planet... Very sad...
WAVE AT OTHER SKYLINES!!!!!!!!!
Bogan :)
Spotted BECKS yesterday arvo merging onto Centenary Hwy Roundabout. I was in the Cefiro
Spotted B3CKS at M1 this morning. I was the black R34 sedan @ T2 Lane :(
Hey!! :)
I wondered if you were on here!
Wish i could cruise in the t2 lane in the mornings!!
Traffic's been crap latley!
See you out and about soon!
As some of you may know I wrote off my beautiful 33 S2 in June. However even now driving an Evo, Skylines still catch my eye. I spotted this hot metallic orange 33 at the Gabba and a gunmetal grey 4 dr 34 on Middle Rd, OUR 34........ :spank:
spotted yesterday white 34 4 door with black rims parked in Kuraby directly accross the street from my place. plates were blacks or something like that. nice car but if your on here i reccomend not parkin on that crest of the hill that guard rail was put there cos dickheads hoon up this street regularly and lose it. would hate to be havin a ciggy on my veranda and have to see a line get crumpled
spotted a white 34 in springwood saturday night with black bonnet no spoiler. looked sweet...
spotted a white 4 door pillerless 31 in coomera today. cant quite remember plates.. pretty sure had gtr in it.... very sweet.
:D:bunny::):bunny::banana:
Spotted Becks in the carpark in the valley yesterday. parked right near you so you could spot me haha
green r33
cars finally back on the road so should see me in there a bit more. you always arrive earlier and leave earlier than me though. im usually up on the higher levels
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
