spotted this on the gateway tolls going northbound .. the owner is off SAU had sau sticker on it .. i beeped but the owner gave me a weird stare .. was in a gold 380...behind u
Also spotted a white R31 aus spec at southbank last nite lapping ...didnt get the plates
Spotted Nismo (john ) poping up everywhere lol
Spotted a gold r34 gtt going past toowong village on Saturday.
Also spotted red r34 gtt pulled up about 30 mins ago at an RBT in indooroopilly. Looked like the copper was givin him some grief.
I always see other skylines around the coast but never stop to think if they post in Sau, some reason they all know to give the peace sign as they drive past lol or the one finger of acknowledgement, any who if any one has seen me around i drive a R33 srs2 Silver 153 KLY howdy
Sorry :)
I didn't know what the beep was for. That does explain why this strange 380 was so eager to stick behind me!
30 mins or so ago, black 34 gt-t fillng up at mobile 1 on old Cleveland? Whatever the road is you take passing carindale to the city.
Also white 33 gtst with sunroof turning onto creek rd at carindale
[/quote
Black 34 was myself. Live right near there. Atleast I believe it was me, so many black 34's in carindale/carina
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
