ima proud boat....ahh R33 driver. could be worse could be a supra, they are an upside down boat :P
at least us 33 drivers have room to swing very small cats in our cars :)
spotted a white R34 2 door with black roof, bonnet and boot on lutewyche rd. looked sweet. didnt see the numbr plate, but had the doof doof blairing
yep thats the same one that has no respect for 50kmh streets been down my street several times doing well over that.
Spotted Silver R35.. at south bank today.. Black rims.. red calipers... side on.. but plates were probs GOD ZLA or something like that.
Also, a white 33 with SAU stickers... hi mate.. sorry i didn't say much haha.. was with the family - normally much nicer than that.. :)
that sucks, im at my parents at the moment, and theres always some bogan that see's my car on the side of the road and decides going fast in 50 zones is the coolest (no skylines yet though)
I drive from coomera to murarrie every day and I am guaranted to see at least 1 skyline.
I tend to see them on the pacific motorway (like this morning) and on creek road (like this morning).
I wave... no one has waved back yet! :laugh:
I drive a sivler 33 coupe with plates 84MAM and have SAU stickers... Please wave back! I may develop a complex soon! lol
saw a silver 32 sedan with a bunch of guys in it
i was comming the other way in the blue 32gtr
u waved then i waved = happy
was down the back of carina near the bread factory p.s did you see that ford nose dive into the ditch on the corner LOL!!!!!!!!
also i see a blue 34gtr who lives near me just off meadowlands road in carina
very nice car mate
Edited by DAS KAMU
I wave... no one has waved back yet! ;)
My mate lives up in Coomera so im up there a fair bit, If I see ya ill defiantly wave :)
I wave... no one has waved back yet! :blink:
hey yeah i drive from nerang to yatala and back every day, pretty sure i followed you down the m1 the other day. i'm in the blue 32 gtr. ah you'll know next time, i'll have the lights an horn goin mental :D
lol sounds like a plan! I follow skylines all the time, I've developing my ninja skills! hehe
Anything is good to distract the fact I'm stuck in traffic!
    • @Murray_Calavera  If I were an expert I wouldn't be in here looking for assistance.  I am extremely computer literate, have above average understanding on how things should be working and how they should tie together.  If I need to go to a professional tuner so be it, but I'd much rather learn and do things myself even if it means looking for some guidance along the way and blowing up a few engines. @GTSBoy  I was hoping it would be as simple as a large vacuum leak somewhere but I'm unable to find anything, all lines seem to be well capped or going where they need to be, and when removed there is vacuum felt on the tube.  It would be odd for the Haltech built in MAP to be faulty, the GTT tune I imported had it enabled from the start, I incorrectly assumed it was reading a signal from the stock MAP, but that doesn't exist.  After running a vacuum hose to the ECU the signal doesn't change more than 0.2 in either direction.   I'll probably upload a video of my settings tomorrow, as it stands I'm able to daily drive, but getting stuttering when giving it gas from idle, so pulling away from lights is a slow process of revving it up and feathering the clutch until its moving, then it will accelerate fine.  It sounds like I need to get to the bottom of the manifold pressure issue, but the ignition timing section is most intimidating to me and will probably let a pro do that part.  Tomorrow I'll try a different vacuum line to T off of, with any luck I selected one that was already bypassed during the DBW swap. @feartherb26  I do have +T in the works but wanted to wait until Spring to start with that swap since this is my good winter AWD vehicle.  When removing the butterfly, did it leave a bunch of holes in the manifold that you needed to plug?  I thought about removing it but assumed it would be a mess.   I notice no difference when capping the vacuum line to it or letting it do its thing.  This whole thing has convinced me to just get a forward facing manifold when the time comes though.
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
