Originally posted by boostimports
sup. saw a whole heap of skylines on da weekend.
anyone seen a r32 gun metal grey - HAS A GTR badge on it.
number plates are something like SLU - 74U i think. Cant confirm. who was that :D anyone on here?
think i saw this one around south bank yesturday at auto salon. im assuming like most ppl he was looking for a park. had a white 32 gtr behind him aswell
I got a red 32.. I live in the ridge :D But i got a stock exhust so it couldnt have been me
Originally posted by xn
bel, lol. yeah she was pretty hot. good call.
i saw a red r32 gts-t revving up around bracken ridge area. it sounded sweet. i was heading the other way.
also saw a white 32 on the M1. prolly on the way to goldcoast.
hey everyone... names hayden.. drive a red 33 (seemingly like everyone else in QLD!) new to brissy, have been driving around but not seen anyone from here yet... im around milton/city a fair bit (i have tassie plates that start with EQ)
hope to see some ppl at the next cruise when ever that is
cheers
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
