Dead stock 1998 Silver R33 S2 GTS25t. See if you can guess the rego...
Live in Wellington Point and drive to Amberley RAAF Base each day so I do a fair few miles. Gimme a wave if you see me.
saw a red r34 at yatala pies on sunday with the plates niz34
very sweet car, i spotted drift r rims, there appeared to be a front mount hiding behind the mesh too :)
Thank you belgarion for your kind words about my car.Yes there is something hiding behind the mesh :D plus some other goodies :Oops:
I did not see anyone in another Skyline where were you ? should have come up and said Hi.
niz i didnt see ya around the car and i was only stopin quickly to get a pie, my car didnt actually turn off thats how quick i was :D
i parked out the front of yatala, pretty much adjacent to your car
chaos... details, now
damnit i thought i was the only green 33 :|
was it green like mine?
Belgarion / nismogirl, sorry i didnt come and say gday at the carpark the other nite, was with a pretty big group (redlineau - mainly gti-rs) and turned around and you'se had gone :S
Hehehe, you said hi to me tho!
But yeah, carpark has been picking up lately, its good.
Hey Peeps,
Well I thought I should post here...
I bought my girlfriends 1996 R33 GTST (white with GTR wing, skirt and rear pod) off her about a week ago after I sold my 2000 n15 SSS (we only need one car...). Was directed here by Harun (RNZ11Z- GTST) and Cam (GTR_Cam - GTR dehh)
Anyway minimal mods so far (ie pod, stealth, Malpassi, 3 inch 5 zigen cat back) the first two done last night...and I still need decent mags cause the s15 ones just don't cut it...
I used to cruise quite often but of late have not had the time...hopefully meet more of you in the near future...I do venture to Milton on the occassional thursday as part of the redline or pulsar group...
Cheers
Neill
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
