yeah i went tonight, im quite impressed myself without being big headed, i never imagined these times with an NA. I got a 14.08 with a shitty start and shitty 60ft, looking at my other time slips from last sat if i can get everything perfect i think i can maybe get a 13.9something hopefully, just see how it goes. I wanna 13 before i throw the new engine in.
pretty sure the silver 34 gtr is a member of these forums
Sounds like it was markr34gtr. He said he was going out ASAP as he has just tuned his car with all the new mods, HKS 2530s etc. What time did he run, he was hoping for 11s with his new found 300rwkw+.
Is that with all your stereo gear still on board?
nah mate, only the amp for the subs is left in, i have to rebuild the whole boot to accomidate for the extra go fast addition but im hoping i can do an as nice or possibly better install, ill do it when i get some time, probably start it next week or something.
Uhm... I did put some in the readers rides thing. But with the new layout, I dont know where they dissappeared to
They have gone to a better place :bscreen:
You will have to repost them in the new gallery section.
Sux I know, but check this really cool one out .....
http://www.skylinesaustralia.com/photopost...500&ppuser=4618
er dude, ur car is na, pauls car beat you once too i believe
my car does a 13.9 and consistant 14.0... am i missing something???????
im totally demoralized now :spank:
my car-->:) <-- me
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
