not sure how to post some pics of my new gtr, just signed up to that photobucket site and put the link in the 'image' icon you click on where you type, totally clueless how to do this so hope it works... anyways hope to see some of you round the traps say hi if you see us.
Just saw a silver 34 on the firmware if tombul rd and st Vincent's rd the passenger was leaning out at processed to do the http://m.memegenerator.net/instance/40550003#sthash.swL5H0xr.uvms look and wave
Spotted 3 33's today :D Those things be everywhere.
Black 33 (Ex member Warwick- I work with him)
White 33 with the plates MI55. Brunette chick on Days Rd, Grange
Red 33 with a chick driving on Webster Rd, Stafford
Spotted a white r34 gtt around 6:30 last night going past yatala heading north was gunning it and tailgating other cars. Also spotted a nice v35 heading south around 8, the last 3 latters on the number plate were SFX. Then saw a grey r32 at the orneau iga today.
You would too if u had one
I doubt it.
Plenty of police around. Some streets are 40kmhr. This idiot feels the need to show everyone how fast it is. Don't get me wrong, looks and sounds mint but seriously, there is a lot of human traffic on the weekends where I live.
Ah idiot drivers in New Farm. Had a MIGHTY chuckle at the idiot in the 599 who almost caused a multiple car pile up on Brunswick street last weekend. And I've seen that GT-R in the area fairly often, guy is a twat.
Lots of skylines around tbar this morning, silvers series 2 33 gtst had hungry jacks on ruthvern
Black series one 33 gtstwith a vented bonnet and black rims heading south on ruthvern
Yellow 34 gtt with the big factory wing heading south on ruthvern
Yellow 32 gtst which I ended up cruising down the gatton bypass with, also got a wave as I turned off... Very clean car
So saw a skyline very similar to Bodos at the BP on albion rd and apart from that saw 3 DeLorean DMC-12 must have been a meet on today. 2 are right here in sandgate.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
