Spotted these two around my work @ Milton. Not Lines I know but still in the family.
Also spotted a back R34 GTT with SAU sticker down at the Regatta late last week.
Dah fark have they done to that 370?
  • Like 1
R33 everywhere!! is there a tsunami coming that some people dont know of?
beautiful deep metallic blue with black bonnet and boot 33 gtst seen in Morayfield area. got a wave yesterday morning :)
A nice silver 33 gtst series 2 in Rothwell yesterday arvo, and a hand full more. so many r33's!
  • Like 1
VSP07 grey infiniti / skyline sau sticker crawling down skyring terrace new farm/teneriffe. son of rajab knows how you got your license.. Not only were you driving 20km to 30km / hr in a 50 zone but your erratic swerving was quite the lulz.
If you want the tape let me know, dash cam doesn't lie... End rant
Edited by defari
Spotted red r35 plates GOZILLA I think. On the Pacific highway near hyperdome tanah Merah Weds round 5 heading towards bris. Black 34 taxi juers rd lastnight good couple days spotting
may have been Tony......but he would be doing 20-30 over the limit :P
Spotted gun metal R32 GTS-T driving onto Ipswich motorway from Redbank on ramp towards Towoomba before lunch. SAU sticker on the quarter window.
Was blowing some smoke out the back and running rough as hell, then slowed down to a halt. Would of pulled over to assist If
I was closer :(
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
