Saw a silver S2 33 last night just before the defect stop on anzac ave he did a u turn at next possible location and I followed suit. Shouldve pulled into the maccas there and had a chat with him :(
so today I spotted that same Red r33 with gtr wing in Ipswich
then on the way home I seen it........the holy grail (for me at least and ford fans........
just mincing along between gold coast and brissy. Still on Texas plates a Shelby GT 500 super snake.......
I nearly tripled my self....... the sound, the look, the stance
tripling : http://www.urbandictionary.com/define.php?term=Tripling%20Yourself
We had a gt 500 parked out the front of work a few months ago. Plates were SNAKE II. it was in mint condition and sounded spectacular, especially with the faint supercharger whine.
you can hear every single one of the horses. and this ones whine wasnt faint
  • Like 1
seen a very sic r35 when crusin in the city saturday night, looked to be a light silver possible metallic white colour if thats possible?? bloody hot looking car non the less!! plates 8mycsh or 8mycash forget which one to busy admiring.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
