Hey guys my name is Anthony,drive a white r32 live in jindalee and work at milton,normally cruise past milton maccas thrusday but never stop,cause i dont know any of ya ,but one i will!
i saw like 20 skylines 33's and 32's tonight, milton macca's and a few other places.....
Ok i was toying with a Grey 33 and a red 33 both GTST on sandgate rd 7/3/04 also there is a purple GTR at my uni plates are AOS33 this bad boy is so ***ing phat mad pioneer system if ur on here speak up and be herd!
Michael
neone on here own a purple GTR, we exchanged waves at indooroopilly shopping center the other day i think the plates might have been 33 GTR??? not sure on that one though
I saw a purple GTR yesterday getting off the Gateway northbound at Eagle Farm.
Pretty sure the plates were 93 GTR.
