saw a debadged white 32 gtr parked in the myer carpark at the hyperdome. saw it as i went up the escalator and had to go back for another look. don't worry, i didn't leave any fingerprints!
i really want one!!!!
Did u want to buy 95SKY qld personalised plates?? i have them, 700 bucks.
Just saw a gunmetal 32 GTR with the no. plate ten57... im sceptical... anyone know it?
No Thanks mate i would of been interested if i still had the 33 but thats long gone now :P
Cheers
saw a white R32 4 door with front mount following me from logan road to capalaba road .. black series 1 IFY rego??.. pretty quick car near carindale.. white veilside R33 shauns ???GPA rego Franklins Mt Gravatt...
I saw a White R33 in the city, parked behind a black 300zx, it was parked infront of a resturant one street over from Queen street?????
and i keep seeing a Burgundy R32, very nice, i love what u have done. I see him alot through Northlakes and sometimes in redcliffe....
I saw a burgundy R33 with a Nismo decal across the bonnet on the corner of Rode and Gympie road, i waved, and got a weird look in reply...
I think i'm going to give up waving, all i ever get is weird looks :S
Your not waving with two fingers pointing up are you?
LOL...
Ive had a few non wavers... I guess the first time they get waved at they just think who was that... Then in time they relise that it was another skyline and they will probablly wave next time. However serial non-wavers should be run off the road and should not be allowed to drive skylines.... LOL
lol serial non-wavers,,,,
was with my mate tonight in his supra, met dudes in purple gts-t 33 in the city,, drove around had a chat and shit , played around a bit on beenleigh rd here and there,, , dunno if they are on here,  prolly shoulda asked,
does you're mate own that supra with the Gen 3 in it? now that's tuff.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
