Im thinking about buying an oil cooler for my GTT
But while searching I came across a thread where someone said that it can be bad to run an oil cooler with standard oil pump
no one replied with anything confirming or denying this claim
I was just wondering what ppl opinions would be on this subject
https://www.sau.com.au/forums/topic/192605-oil-cooler/
pfft, some poeple have no idea
just put it in, know one boots there car in the 1st 5 minutes of it running, it take bout 1 minite longer to get to normal working temp.
you wont notice it till you on the track and your oil temp wont go over a surtian temp.....
only install oil pump when your building the bottom end of ur engin and be sure to install a bigger sump.
xoxoxo
https://www.sau.com.au/forums/topic/192605-oil-cooler/#findComment-3460681
Im just a little concerned at my oil temp
cruising around town it sits on about 100
but lately with summer kicking in up here its starting to head up closer to 110 deg with air conditioner on
god forbid I head to the highway
water temp is fine
*this are taken from the factory gauges ,they may or may not be accurate
https://www.sau.com.au/forums/topic/192605-oil-cooler/#findComment-3461002
xoxoxo
Just curious, have you had an oil cooler and oil temp gauge?
https://www.sau.com.au/forums/topic/192605-oil-cooler/#findComment-3461041
water temp is fine
water temp and oil temps are related so if ones fine the other should be okay, those temps seems normal i wouldn't worry unless it goes above 125ish.
also the temps should be lower if anything on the highway due to more airflow and less revving.
if you don't do alot of hard driving or trackdays i wouldn't worry about an oil cooler.
https://www.sau.com.au/forums/topic/192605-oil-cooler/#findComment-3461345
battery Posted Today, 02:48 PM
just make sure you get a thermostat otherwise it will takes ages to get the engine up to operating temp and/or make the temps to low thus creating wear.
do most kits come with a thermostat or do you usually buy it as an extra, never really heard of a thermostat on an oil cooler
https://www.sau.com.au/forums/topic/192605-oil-cooler/#findComment-3461548
Ideally you should have the oil temps close to the water temp again this will be effected by fitted oil coolers and power output etc on different cars.
have to say that 100 seems a bit high for cruising but i have found the factory gauge to not be all the acurate. still 100 is not damaging the oil i believe mineral based oil starts to break down around 125 again depending on the quality of the oil. But again 90 is better than 100, how dark is the oil when changed?
I may be wrong but oil pumps are positive displacement gear pumps so really shouldnt be an issue with a standard pump or after market, unless there is to much restriction in the cooler you use, resulting in oil pressure drop. and thats a bad bad thing!
I run 3 coolers on a standard pump ( well i think it is ) and had no issues yet, long may it continue.
https://www.sau.com.au/forums/topic/192605-oil-cooler/#findComment-3461556
Oil cooler is a waste for city driving.
Only a good mod if you hit the track, otherwise there is little benefit.
If you don't ever plan to hit the track then don't bother is my opinion. Quick fix= get oil temp. gauge and that will show you how hot the oil is in summer with air con. running.
https://www.sau.com.au/forums/topic/192605-oil-cooler/#findComment-3461576
I never see my oil colour as it get changed by my mechanic
He uses royal purple and tell me that they are a pretty stable oil at high temps
but still In my mind its high
could putting a bigger turbo on it make it rise by 10 degrees its used to sit on around 90degrees with the old turbo
https://www.sau.com.au/forums/topic/192605-oil-cooler/#findComment-3462269
they usually don't come as part of the kit but u can usually get them as an extra.
you should make it a habit to check the oil level every so often when filling up.
i usually check the oil and tyres once every two weeks or so.
https://www.sau.com.au/forums/topic/192605-oil-cooler/#findComment-3463403
I've been told it isn't good to have an oil cooler unless it's intense endurance races?
My water temp will sit at 80ºC but my stock oil temp gauge has always sat at 70ºC.
I've been told this isn't good for my engine because the oil isn't warming up enough and can cause wear to the engine?
https://www.sau.com.au/forums/topic/192605-oil-cooler/#findComment-3465496
    • I am getting the same issue. Did you resolve it? I just got it after installing my new super coppermix and literally the same issue, new fork, new 18mm carrier, release bearing that came with the kit and replicated the exact same sound.
    • If you like - I have the STL files so I can email em. There's a couple of gotchas (i.e the holes are not threaded so you might need/will need) to utilize some M3 melt-in threads for some of the points. However if you want to be super accurate, and are willing to remove your calipers and your SHOCKS it's a really good tool. You also might need to scale the part that measures the tyre width a bit wider. It defaults to a 7.5in tyre and I mean who is running that. Luckily with the magic of CAD this is very easy to rescale.
    • jeebus. glad you weren't under it while performing the stunt. Also thanks for the link to the wheel measurer, exactly what I needed
    • In the older stuff there were very significant differences 2wd to 4wd, for example Stagea had strut front end for 2wd and double wishbone for 4wd so it was not minor to swap. From poking around the 2wd v37, it *looks* like it might be more possible; some of the parts specifically have "2wd" stamped on them which suggests the platforms are more similar. You'd still want to start with a 4wd half cut to swap stuff from though. I'd suggest if you don't have a tune on the ECU you don't really need one on the trans either. Throttle mapping is in the ECU side (and you can always use a Roar Pedal if you want the throttle to actually respond to your foot), and really if you are happy with the stock power you probably accept the stock trans behaviour too....its all made to be "sporty" not racey.
    • So, updates. I have not washed the car since it came back from Tassie. I've driven it around a bit but not got around to actually sorting it out. I DID raise it because I cracked the rear bar leaving a hotel which was very distressing. Interestingly, the car drives more compliant now that it's raised a fair bit (5mm front, 15mm rear). Also noticed that my FR height was 10mm lower than FL. So that's now sorted out, too. I also bought this and had it printed: https://www.etsy.com/au/listing/1576422240/wheel-and-tire-fitment-tool-universal?ref=shop_home_feat_1&dd=1&logging_key=08f604d9fa4cc383550ba985e6ac85cd5cac7fbb%3A1576422240 Now, if I was smart I would have taken my brake calipers off to actually use this correctly but it was evident enough to me that in the region where the caliper was... there was nothing to hit suspension/guard/arm wise. So I'm going with "it'll be fine" after using the tool to hopefully very precisely measure the wheel clearance. Also while doing this, I had the very VERY bad idea of jacking one of the wheels/suspension arms up while the rest of the car was on jack stands. I did this to see how the arm would travel. This all was well and good until the car slid off the stands and went through a fence. So don't do that. Incredibly nobody was hurt and there was only minor damage to the rear bumper as the car didn't have far to slide, and had 3-4 wheels on it. The only damage turned out to be the fence itself which was easy to fix, and a little bit of damage to the fibreglass rear bumper trim. I had already planned to try a touch up paint kit to fix the time I drove into my garage door to see if it'd help in the interim before I get it fixed properly. I used the Dr Colorchip kit after looking online and seeing everyone talking about it. Yes it's made for chips and not huge broken missing pieces and I'll be 500% recommending it for stone chips after using it for stupid things like me. This took about ... 10 minutes and looking at the half assed photo the 30 second job I did on the bumper corner was almost perfect just by using the tiny little brush and painting it in. The sealact stuff to remove over-painting is really useful, so if/when I do it again I'll likely slather the touch up paint well over it and then clean it up with the cleaning solution. The wheels should arrive in a couple of weeks. I am still kinda confident after doing a stupid amount of measuring (and borrowing a set of 18x10.5+15) that they will not fit because I overlooked something, somehow and flew too close to the sun. ALSO R34 GTR guard liners do not fit on a GTT. I bought the undertray brake duct guides and had the wonderful problem of them not fitting my intake, my oil cooler and the liners themselves were even worse. Attempting to fit them won't work in general - You would have to cut them up as another poster mentioned as the bodywork is different on the GTT. At least I can try to resell them. So instead of cutting those up, I cut up my old already-cut-up GTT liners and extended them by using some PP plastic and drilling some 8mm holes for some nissan clips for the 'extra' bit. Because I was happy to cut them I was able to mount them pretty damn forward so I now have some semblance of guard liners, and the brake vents seal the bumper from the bottom. It sort-of-looks like this, to give some idea - If you look at the GTR and then the GTT this is when I realised that I needed to seriously measure as the inside of the rim area is entirely, entirely, entirely different and could not take any internet measurements for granted.
