  • Replies 72
Get the defi sports cluster! very nice.
pretty good value too, I would say quite a bit cheaper than the stack or MXL dashes:
lot's of cool features and of course logging capability.
https://www.sau.com.au/forums/topic/193465-stack-dash/#findComment-3471791
I had a quote of $2800 for the Defi. It's pretty damn schmick, but a touch pricey... having said that, the Pista is looking to be around $2500 optioned up with boost sensor etc, and the STACK is $1600 +$500 or so for timing gear, plus having to buy a boost guage... so not a lot of difference.
Technically you can't purchase the Defi outside of Japan, as it is supposed to be installed by Defi and Defi only. Have a contact to get one, but it's pricey. Wanna pick me up one in Japan Richard? :P
Also, the track mapping doesn't work outside of Japan, which is a shame.
https://www.sau.com.au/forums/topic/193465-stack-dash/#findComment-3471815
2,800 ouch. But if you add up the cost it's probaly a nice christmas present
+ comprehensive array of guage$ you wont need
+ getting rid of the cluter
+ hard corey feel
= reasonable value
does it have a beautiful opening ceremony lol?
https://www.sau.com.au/forums/topic/193465-stack-dash/#findComment-3471821
I don't see why you would go this way.
I run
oil temp
water temp
oil pressure
volt
boost
fuel pressure
exhaust gas temp
wideband 02
in addition to stock revs, speed, torque, dodgy oil pressure, etc etc standard dash
and the 02 sensor comes with 1mb data logger with 7 inputs.
under $1500 all up
https://www.sau.com.au/forums/topic/193465-stack-dash/#findComment-3472264
Yeah, I'd say the defi is the pick of the bunch, but it's very pricey...
NIB: Could you elaborate mate? Which AIM are you using? Is yours wired into the ECU, or standalone?
Duncan: I just had oil temp, oil pressure, boost and water temp guages which I've sold. I want to clean up the dash area, as well as having the ability to time laps.
The money I got for my Defi's, plus the sale of my stock cluster with 280km/h speedo, and my ECUTALK display, PLUS having to purchase a lap timer, has meant that the cost of buying one of these units is not too bad, hence why I'm going this way.
https://www.sau.com.au/forums/topic/193465-stack-dash/#findComment-3472999
I havent seen that on the Defi site, has it been released yet Richard?
yeah it's been out for about 2 years or so, but defi do not retail it for OS markets. nothing to stop you buying one in japan though :wave:
Dane, if you really want one I can grab you one from japan. much cheaper than $2800 for sure.
I say do it, you will have the first one in aus that I know about.
https://www.sau.com.au/forums/topic/193465-stack-dash/#findComment-3473090
i use a epson ej-1 driving emotion system with a nismo dash (the one with the tv in it)
its pretty good system which display
i've still tring to work up how to setup all the data logging function as all the info i have on it is in Japanese :wave: but what i have worked out it awsome!
https://www.sau.com.au/forums/topic/193465-stack-dash/#findComment-3473249
A mate has a Microtech dash in his RX7, it doesn't look very pro, but has pre-set values for warnings ect which do get your attention. Does Defi allow that?
I assume Motec dash is double the price of these?... much nicer to use though.
https://www.sau.com.au/forums/topic/193465-stack-dash/#findComment-3474932
Yep, sure does mate, as does the Stack and the MXL.
I used to have a microtech dash in my old RX7. Was quite basic, but showed you everything you needed.
Not sure how much the Motec dash is, but I don't run a motec and I think it takes it's reading directly from the ECU. It looks to be very similar to the MXL anyway, and I can make the MXL standalone.
This is a link to each for reference:
ST8130
http://www.stackltd.com/st8130.html
Pista
http://www.aimsports.com/products/mxl-pista/index.html
https://www.sau.com.au/forums/topic/193465-stack-dash/#findComment-3475845
I think its important for the unit to bring your attention to problems, I rarely pay attention to secondary gauges.
Motec dash can be stand alone also.
The stack unit looks clean and simple... the Defi one looks too road car.
https://www.sau.com.au/forums/topic/193465-stack-dash/#findComment-3476083
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
