What is the benefit of putting a catch can on my RB25 with only light mods (intake/exhaust/boost)? Is there a point? A mechanic told me its a good idea but i'm not sure myself if there is a benefit with the engine staying around 200rwkw.
Any advice?
Thanks :wave:
https://www.sau.com.au/forums/topic/193576-do-i-need-a-catch-can/
  The Mafia said:
I'm running 300rwkw and I still don't have one.
Fair enough. I know my 33 can get by without one too, but is there a benefit? Is it only essential for big power?
Or is it being pedantic?
well it recommended for cars with bigger power, however i cant really hurt having one installed, the other topic further down talks about positioning of them and what to hook up where any more advice in this thread would be appreciated!
  dmr said:
catch cans collect the oil, moisture and gas that causes crap to build up in your intake. i think they're a great idea even on low powered cars
So really all you're getting is lowered maintenance intervals? i.e. throttle body cleaning
It's not a major issue for most Skyline owners i take it
  • Like 1
  H@ME said:
i just finished mine then in this thread http://www.skylinesaustralia.com/forums/Oi...ug-t129549.html
Just saw it, left a reply.
I'm still 50/50 whether it's a necessary mod on a mild setup
Someone convince me :wave:
Oil vapour being injested can cause detonation...so if you can somehow reduce the amount injested by using a catch can or similar why wouldn't you...its not limited to high power cars...and its got nothing to do with lowered maintenance intervals...but with almost any mod...its not necessary...
Edited by limpus
it's not a major issue as such, but it's a good upgrade with bling factor for a little extra health for your engine :wave:
Don't know if this is true, but I have heard that the 'effective' octane of fuel is reduced by oil vapours, including reducing the amount of oxygen available to burn.
Don't think it can hurt to have one, but as to how much HP you gain, is up for debate.
Fixxxer
Fixxxer
That makes sense. I guess it would come into play when the oil gets HOT, when your redlining it.
That's pretty convincing from a performance POV...
They're going on Nengun yeh?
it wont add any power at all
if you do fit one and it keeps filling up time to fix the source of the problem
some people fit them to catch heaps of oil in the intake, this isnt a fix its just masking the problem
it could be shagged oil seal on the turbo etc
^^^ Agreed...if a catch can keeps filling up then there is something more serious going on...
However...if for some reason you are getting some blow by and it is being ingested into the engine...then it might cause detonation...with a catch can in place...you will not get any performance gain at all...however...if you stop the blow by from being ingested...your detonation threshold might go up and you might be able to run more timing...hence getting a performance gain...the gain is not from fitting the catch can...but its from the catch can doing its thing hence allowing more timing to be added...
Edited by limpus
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
